Spark Plug (Pic)
Old Jul 29, 2009 | 03:02 PM
  #26
98vtec's Avatar
moderator emeritus
Default Re: Spark Plug (Pic)
if it were possible that your engine did in fact go into boost in the lower rpms sub 3500, the engine is not going to like all that timing. You're going to hear the engine scream, for lack of a better term. High loads and low rpms are the most vulnerable areas for an engine to detonate its *** off and pretty much just kill itself over time. Look at the transfer of ignition timing going into boost and that pretty much tells the story all by itself. I bet that little *** turbo you are running could actually acquire boost at low rpm. Just be careful.
Old Jul 29, 2009 | 03:16 PM
  #27
zach1288's Avatar
I think I start building boost around 3k. I can't believe the timing is not correct my tuner is very good.
Old Jul 29, 2009 | 05:28 PM
  #28
Blown90hatcH's Avatar
Originally Posted by zach1288
What plugs should i be using? If i put a different plug in will it effect the tune?
Put the same ones in it. YOu just need fresh plugs to be able to read them better.
Old Jul 30, 2009 | 12:28 PM
  #29
zach1288's Avatar
Update:
I posted the wrong map.
I went to my tuner and he pulled the chip in my ECU. He showed me the map and the timing is correct.
Old Jul 30, 2009 | 12:52 PM
  #30
roadsqueegy95's Avatar
is nate the guy that tunes at wyotech?
Old Jul 30, 2009 | 01:08 PM
  #31
zach1288's Avatar
Yes sir. He is a teacher there.
Old Jul 30, 2009 | 02:10 PM
  #32
ya when i graduated up there they had just finished building the new building for them! i was pissed i wanted that class!
See Are X
Jan 1, 2006 11:18 AM
gunnis
Nov 9, 2005 06:06 PM
chads
Jun 4, 2005 02:32 PM
alexsracing
Apr 24, 2005 04:01 PM
Floyd
Jun 18, 2002 01:35 AM
