Spark PLug Gap?
Old Sep 6, 2002 | 09:42 AM
madman604's Avatar
Default Spark PLug Gap?
I read somewhere on this board that the wrong gap can cause Misfiring after 5psi of boost. is this true?
My setup:
JDM B18C
Greddy GSR Turbo Kit
plugs gapped at .04 NGK heat range 7
I was using NGK laser Platinums gapped at .03 earlier and it ran fine, just wanted some input before i pulled the plugs. I though some wires may have come loose.
Old Sep 6, 2002 | 10:20 AM
ekb18c's Avatar
Default Re: Spark PLug Gap? (Turbo E)
Try gapping them at .03 to .035. I personally don't use platinum plugs, I don't know how others feel. I normally use NGK BCPR7ES-11 for low boosted cars.
Old Sep 6, 2002 | 10:50 AM
shifthard's Avatar
Default Re: Spark PLug Gap? (ekb18c)
i use ngk bkr7 and i gapped them at .03 dont have problem so far....knock on wood
Old Sep 6, 2002 | 11:20 AM
madman604's Avatar
Default Re: Spark PLug Gap? (shifthard)
hmmm... methinks .03 seems to be the magic number. I figured that since i was using a Crane Ignition System it would be able to jump the larger gap. I guess the High compression and boost wouldn't have any part of it
Thanks for the input guys
fremontcivic
Jan 11, 2011 01:21 PM
123Four
Sep 22, 2007 03:28 PM
nickolas388
Oct 26, 2005 08:01 PM
SpeedMonkeyRacing
Apr 24, 2003 08:55 PM
CalvitoSol
Jul 1, 2002 01:19 PM
