Spal fans?
Old Dec 27, 2002 | 10:26 PM
R-1303's Avatar
Default Spal fans?
using it with a 38mm fluidyne for a ITR-turbo, will it provide enough clearance between the radiator and turbo? also does it plug into the stock harness?
Thanks, mark
Also i'm looking to buy the fans so do you know where to get the cheapest prices?
Old Dec 28, 2002 | 11:15 AM
R-1303's Avatar
Default Re: Spal fans? (R-1303)
anybody?
Old Dec 28, 2002 | 02:35 PM
tygsr's Avatar
I know the FAL fans do, but they are pricey. I have looked into the spal as well..
Old Dec 28, 2002 | 02:37 PM
itr449's Avatar
Me too, anyone?????
Old Dec 28, 2002 | 11:18 PM
accordking's Avatar
Default Re: Spal fans? (itr449)
my friend picked up a Hayden fan from Kragen for about 80 bucks.
Old Dec 29, 2002 | 05:13 PM
turbo Si's Avatar
Default Re: Spal fans? (accordking)
Try the unversal slim fans from Orielly or Autozone. A 10 inch fan runs about $70.00 bucks, and works great. Alot a turbo Honda's in Houston use them. There the best for the buck!
Old Dec 29, 2002 | 08:00 PM
s2k1's Avatar
Default Re: Spal fans? (turbo Si)
Spal makes great fans. To the best of my knowledge they provide more cfm per inch in diameter than all the other fans on the market. The fans will not plug directly into your stock harness. I have 2 of them on my off-road car. They are widely available. I buy mine through ORW in SoCal. That is, Off Road Warehouse.
Old Dec 29, 2002 | 08:22 PM
echo999's Avatar
New User
I have a GSR with Fluidyne fan. I only have approximately 2.5" of clearance between the radiator and the turbo (hot side).
to not melt the fan, you need to try and have some extra clearance.
I opted with the SPAL 7" fan, and ran it towards the side.. Regardless,
the fan started to melt, so I bought some aluminum tape, and shielded
all the exposed parts. The fan's still working, so I'm assuming the shielding
I taped on works ok...
Anyway, a 7" fan for the driver's side works just fine.. don't need anything bigger.
ek99civic
Jun 7, 2007 03:43 PM
Skunk.Werks
May 17, 2005 07:45 PM
Muckman
Jan 20, 2004 12:20 PM
BoostedH23a1
Apr 13, 2003 04:24 PM
