sorry to do this but....quick saturated or PH injector question....
ok i have searched and i know this is a common question.. but i have a 92 accord with a resistor box ( running 1000cc precision injectors) now i just want to run some RC injectors that are saturated... can saturated injectors be run even if i have a resistor box? thanks guys... sorry for the "stupid question"
Nope... the injectors won't get enough juice to run. Basically you're dropping voltage and then dropping voltage again.
kool... thanks for the post... ummm what would you recomend i do ... i need some smaller injectors... (550's or so...) like i said, i have precision 1000's but those ******* are hard to tune... (uberdata) so im only going to be running small boost ... like 8-9 lbs (non sleeved h22) so i want to get some smaller injectors so i can tune my car myself...
why dont you just get some peak and hol 550cc they make them no problems and you dont have to worry about changing your wiring.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo »</TD></TR><TR><TD CLASS="quote">why dont you just get some peak and hol 550cc they make them no problems and you dont have to worry about changing your wiring. </TD></TR></TABLE>
haha oh yeah.... well i just figured it would be easyer to get some old dsm's and not have to spend a **** load on newer ones... how much would a man have to spend to get some PH 550's?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboH22Aakkord »</TD></TR><TR><TD CLASS="quote">haha oh yeah.... well i just figured it would be easyer to get some old dsm's and not have to spend a **** load on newer ones... </TD></TR></TABLE>
old dsms are 450cc peak & hold, you'd be all set with those
1000cc's aren't that hard to tune. Just play around with them some. You'll get them to idle right. I've done it before in uber. You may need to idle them richer than 14.7:1
yeah, i got these ones to idle pritty decent but the other tunning was friggen difficlut.. every adjustment i did screwed **** up...
wtf dude. i had 0 problems tuning 1000cc injectors. i even taught myself to tune on 1000cc injectors. w/ uberdata even. I been following you for some time now.
whats going on w/ these jectors and things changing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Shane »</TD></TR><TR><TD CLASS="quote">wtf dude. i had 0 problems tuning 1000cc injectors. i even taught myself to tune on 1000cc injectors. w/ uberdata even. I been following you for some time now.
whats going on w/ these jectors and things changing.</TD></TR></TABLE>
well i ended up trying to tune them ... and i even got them to idel and stuff... but i couldnt tune the rest of the vaccum stuff.. let alone even getting to the boost portion of tunning... i would make adjustments and **** would go all to hell... when you tuned did you use an sort of datalogging?
well if you really dont feel like dealing with the 1000cc just do what some others said. old dsms are peak and hold and you could also just get new Precision or RC peak and hold if you wanna spend the money. that way you dont have to change the wiring.
also check the classifieds you might even be able to find some on here to do a trade
