Someone please explain clutch discs to me.
Old Jul 16, 2001 | 05:28 PM
boomslang's Avatar
Default Someone please explain clutch discs to me.
When people speak of better engagement with a puck clutch, what does that mean? Will a normal street disc slip a little as opposed to a puck disc grabbing immediately?
RPS stage 2 clutch will hold 600 hp with an OEM disc, whereas the stage 3 holds 700 hp with a puck disc. I know the puck one will be harder to drive and be all chattery, so what are the major advantages of it over an OEM disc? (for street/strip cars with less than 300 hp)
Old Jul 16, 2001 | 10:28 PM
TurboInteg95's Avatar
Default Re: Someone please explain clutch discs to me. (Inlinefour)
well usually the better disks are made of a better material that isnt as forgiving on the flywheel and dont last as long as a stock clutch. the actual clamping power is in the pressure plate. a good street setup is the ACT extreme pressure plate with street disk. the disk has brass fibers embedded in it to increase friction and resist burning as easily as a stock clutch. another difference in the disks is whether the hub has springs or not. an unsprung hub will grab immediately and sometime make for a little bit of a jerky take off in a street car. a sprung hub absorbs the initial grab of the disk making it engage smoother.
Old Jul 16, 2001 | 11:16 PM
VaporTrail's Avatar
New User
Default Re: Someone please explain clutch discs to me. (TurboInteg95)
but, a sprung disc has it's downsides. If the spring breaks, or comes loose, it can also destroy the pressure plate and/or flywheel.
Old Jul 17, 2001 | 01:07 AM
Liltrix's Avatar
Default Re: Someone please explain clutch discs to me. (VaporTrail)
So I guess the question is what do U recommend on a turbocharged street/strip car?
Old Jul 17, 2001 | 08:36 AM
Default Re: Someone please explain clutch discs to me. (Liltrix)
I've only been in one car that had an unsprung hub but I didnt like it at all. I dont think I would ever get an unsprung hub for my Integra but I'm thinking about getting one for my Corolla.
ganjasnack
Jul 21, 2008 01:38 PM
juergen33911
Jul 9, 2008 11:16 PM
sirguy01
Apr 22, 2006 09:21 AM
350z-tech
Nov 13, 2001 08:44 PM
350z-tech
Nov 13, 2001 08:13 PM
