Some tips for those with Blitz SBCid Boost Controller and Similar others
Old Dec 5, 2001 | 11:23 AM
GruvyTune's Avatar
New User
Default Some tips for those with Blitz SBCid Boost Controller and Similar others
hey everyone. After a discussion with Blitz, I discovered a really great method of setting up the boost controller (their instructions suck and don't tell you this).
If you are boosting any less than 12-14 psi, leave your top port on your external wastegate open. Run the compressor fitting to the inlet on your boost controller solenoid and the output into the side port on your wastegate.
Set the boost controller to Actuator type (rather than external--which it really is) and set the control method to manual rather than automatic. You will now have to set the pressure to a percent of the duty cycle. On mine I have to set to 15% to get about 7.5psi and the gain set to about 30 which gives me awesome boost response and great reproduciblilty (is that a word?).
torin
Old Dec 5, 2001 | 02:17 PM
PureTeg420's Avatar
Default Re: Some tips for those with Blitz SBCid Boost Controller and Similar others (GruvyTune)
hmmm, as soon as UPS quits trying to screw me over and gives me my display, i will make sure to give that a try.
hold your breath
Mar 6, 2007 07:47 PM
lsvtecvx
Jun 4, 2003 03:34 AM
stockgreencivic
Apr 10, 2003 07:32 PM
hXc-DC2
Oct 15, 2002 06:38 AM
clean
Oct 18, 2001 11:16 AM
