Some interesting results...
Old 03-20-2005, 11:57 AM
Tinker219's Avatar
Default Some interesting results...
Both runs are at 10psi, 60-1 turbo.
The lower run was with a Drag manifold(unsure of downpipe size), H22 motor, 327whp/249wtq.
Customer ordered an H22 Mini-me and 3" downpipe, only things changed on the setup.
These were the results, +101whp, +63wtq, or 428whp, 312wtq.
Must mean something is working! I will try to get more pictures, details etc over the next couple of days, just thought Id share his findings thus far.
Old 03-20-2005, 12:14 PM
dan_w_82's Avatar
Damn that was one nice increase in power. congrats to the owner and the shop for more props.
Old 03-20-2005, 12:19 PM
m R g S r's Avatar
Default Re: Some interesting results... (Tinker219)
leaned out?
101whp gain on only 10psi....****** awsome!
Old 03-20-2005, 12:22 PM
Tinker219's Avatar
Default Re: Some interesting results... (m R g S r)
I believe the AFR is richer than the 330whp run, at least down low. Upper is virtually the same.
I am unsure of other conditions, if timing was changed or not, Im hoping the customer will chime in with these answers. From my understanding, he bolted it on, adjusted the AFR and this was the result.
Old 03-20-2005, 12:45 PM
dan_w_82's Avatar
That **** is just crazy DAMNNNNNNN I had to come back and post again. I wish I could make some power like that.
Old 03-20-2005, 12:47 PM
Kwuaymaikrup's Avatar
That is pretty inceredible
trentepic's Avatar
Can u say Rigodmanedfrickindiculous
Old 03-20-2005, 01:14 PM
HiProfile's Avatar
Default Re: Some interesting results... (trentepic)
Wow, thats almost surprising. Not the fact of an increase, but the amount of the increase.
BTW - Blue line = 400+hp run, blue line = richer run. The only time it was leaner was before 3.1k and right at 6k. I'd like to see how it does at the same a/f ratios, bet it'd be even more of a diff. Good job
Old 03-20-2005, 01:24 PM
EF'n's Avatar
Default Re: Some interesting results... (HiProfile)
wow, LoveFab rules.
Old 03-20-2005, 01:37 PM
Tchleung's Avatar
That's jsut scary. I bet that was the customers best investment yet! lol
Old 03-20-2005, 02:27 PM
Brrraaaap!
Blaze45's Avatar
Default Re: (Tchleung)
WOW..... Nice work Cody~! More info!
Blaze
Old 03-20-2005, 02:35 PM
oxSLEEPERxo's Avatar
Default Re: (Blaze45)
thats a nice jump
Old 03-20-2005, 07:33 PM
Turbocivic94's Avatar
Default Re: (oxSLEEPERxo)
Sick
Old 03-20-2005, 08:09 PM
Ls1 FD3s's Avatar
Default Re: (Turbocivic94)
2.2L + boost = TRQ!
totally siiiick
Old 03-20-2005, 08:37 PM
drift2004's Avatar
Default Re: (Ls1 FD3s)
hell yeah i order the right one then!
Old 03-20-2005, 08:45 PM
lalspeed's Avatar
Default Re: (drift2004)
damn
speech less
Old 03-20-2005, 08:49 PM
DOHCarp's Avatar
Deffinatly impressed!!!!
Old 03-20-2005, 09:31 PM
*Boostwerks*'s Avatar
...I'm assuming the dip in power is from the vtec point?
But non-the-less...100hp from a manifold switch...
I can't wait to get my setup finished!
Old 03-20-2005, 10:20 PM
Nikoli's Avatar
Default Re: (Bryson)
too bad you cant keep tha AC with manifold . otherwise i'd have one
Old 03-20-2005, 10:41 PM
Default Re: (Deckedlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deckedlude &raquo;</TD></TR><TR><TD CLASS="quote">too bad you cant keep tha AC with manifold . otherwise i'd have one</TD></TR></TABLE>
He makes A/C Mini-Mes as well. I dunno about the H series, but D and B yes.
Old 03-21-2005, 03:58 AM
Tinker219's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls1 FD3s &raquo;</TD></TR><TR><TD CLASS="quote">2.2L + boost = TRQ!
totally siiiick </TD></TR></TABLE>
I know, hes got the same tq as my S2k does HP. I need to turn up the boost...
Just waiting till after Florida, dont want to go blowing anything up 1400miles from home...
I can build an AC H22 Mini, or SST(still make those for the H's, as nobody else ever has/does), but you must AX the front motor mount and get ready to cut the $*(# out of your Xmember.
Old 03-21-2005, 06:42 AM
mrbsponge's Avatar
holy bajesus cody
thats freaking amazing
Old 03-21-2005, 06:46 AM
FOrSfEd's Avatar
Default Re: (mrbsponge)
SUPER NICE NUMBERS
Old 03-21-2005, 06:59 AM
EJ1 wilcox's Avatar
Default Re: (FOrSfEd)
Very impressive
Makes me want to start saving so I can ditch my Drag manifold for something else...
Sounds like a great product!
Old 03-21-2005, 07:00 AM
ares650's Avatar
Old set-up was a Drag gen-2 mini (the one that looks like an elephant trunk) and top mounted turbo. 2.5 in downpipe into a 3in exhaust after the engine.
New set-up is a Lovefad mini-me with a 3in downpipe. Timing was not changed at all. The weird part was that I had to pull a lot of fuel out to get that A/F.
Worth every dollar.
Quick Reply: Some interesting results...
