solving the overheating problems
Old Sep 17, 2007 | 03:56 PM
  #26
2point2's Avatar
Default Re: (mike1114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">bringing this back to the top for more ideas.</TD></TR></TABLE>
Sometimes a bad tune (timing too retarded) can make the manifold heat up more than normal. my under-hood temps can change a noticeable amount depending on my idle tuning.
I think hyabusa hunter's post explains why some people seem to have cooling problems for no reason at all. once you start screwing with hondas design these sorts of problems pop up out of nowhere..
Old Sep 17, 2007 | 05:17 PM
  #27
JDM KID 510's Avatar
Default Re: (2point2)
Old Sep 19, 2007 | 11:58 AM
  #28
austrian type-R's Avatar
Default Re: (JDM KID 510)
My friend welded a bracket for the new intercooler location. Th eIC is about 6cm lower than it was before. I bought a new K&N arfilter and relacated it a bit. A heat shield is around the turbo housing now and on the intake pipe from filter to turbo inlet. I am still waiting on my bigger oil cooler
brake duct
Mein Spezi hat mit eine Halterung fpr den LLK geschweißt, der nun 6cm weiter unten sitzt als vorher. Den Luftfilter hab ich bisl anders montiert und die Chargepipe + das Turboabgasgehäuse einbandagiert.
brake duct:
Old Sep 27, 2007 | 04:57 AM
  #29
Muzz's Avatar
Looks good, still having any cooling issues?
Old Sep 27, 2007 | 05:28 AM
  #30
Default Re: (Muzz)
can´nt tell yet, since I was not at the circuit since I did the modification. I will let you know
89lowlude
Jan 6, 2013 04:12 PM
ekim952522000
20
Oct 20, 2009 06:14 PM
austrian type-R
Sep 5, 2007 12:58 PM
riceball777
Aug 13, 2006 08:06 AM
