SOHCs with larger turbos how bad is your lag? Mine sucks!
My lag pretty much sucks and I want to know if its normal or if something is wrong with my setup. I have my controller set at 15psi and I see maybe 10psi max at 4500-5000 and in second it builds 15psi right as it hits redline. In third gear i see 15psi right at 5500 but since I have to shift at 7000 it feels like I have to shift right when the car is starting to pull and when I shift it falls to about 4500 and looses half of its boost and has to spool again.
Here is my setup
d16z6 with stock sleeves
crower I beam rods
cp 9:1 .020 over pistons
stock head
arpstuds
y8 intake manifold
turbonetics t3/o4b .63ar stage 3 wheel
turbo xs rfl bov
jrc intercooler
uberdata 1.66
modified wrx injectors (800+ ccs)
gm 3 bar map
I am starting to wish I had a t3 again because my built motor is not much faster than my stock block t3 coupe was because the t3 pulled all the time. The t3/t4 is sick when it spools but falls on its face when I shift. I have pressure tested all my pipes individually but not the system as a whole. I use t bolt clamps and silicone couplers on every connection and they are all tight so I am pretty skeptical about them leaking. Any ideas or is this normal?
Here is my setup
crower I beam rods
stock head
arpstuds
y8 intake manifold
turbo xs rfl bov
jrc intercooler
uberdata 1.66
gm 3 bar map
Re: SOHCs with larger turbos how bad is your lag? Mine sucks! (omahaturbocivic)
Downpipe/exhaust size?
You could try switching to a .48 A/R hotside. That will help spool up some.
Re: SOHCs with larger turbos how bad is your lag? Mine sucks! (RyanCivic2000)
2.5 inch open downpipe that dumps right at the shifter, I ditched my exhaust trying to fix this problem which helped because it was even worse. All smooth mandrel bends.
I know the .63 ar is a bit big but I am skeptical if the .48 would help that much, im looking for more than a few hundred rpms. If this is all the better it is then I am gonna need something more drastic like spings and retainers for a higher redline or nitrous. I was prepared for lots of lag with this turbo but I did not expect it to fall out of boost as bad as it does.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 »</TD></TR><TR><TD CLASS="quote">Full 3" downpipe and exhaust and .48 A/R would make a big difference.</TD></TR></TABLE>
I might look into a .48 soon then. I am still skeptical that my 2.5 open pipe is much worse if any than a full 3inch exhaust. Does having the exhaust point staight down cause excessive turbulence?
With a larger turbo, having a 2.5" downpipe will cause backpressure on the turbine even if the dp is open. You would be surprised at the difference a 3" downpipe can make.
i wonder if a stg 2 wheel .63 a/r would work well for 15psi. If the compressor isn't huge it would be alright on a d16 i think. never seen it though.
you have a leak or something. Im running a .63 exhaust housing on my T3 and it spools pretty ****** quick. starts at 2000 2-5th gear and hits max around 45-5000. Holds well till readline.
You've gotta have a leak. Im running open DP though btw.
I bet one of the charge pipes is leaking. Also check exhaust leaks. It's hard to hear over the open DP thoug.
when does it start spooling?
I just sold a t3/t04b .48 the other day for $150. on my B18c1 it spooled at
less than 2500rpm had mid range like crazy. Now iI went to t3/t04e .63 don't
see boost till 4500 on my 1.8 liter
Re: SOHCs with larger turbos how bad is your lag? Mine sucks! (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch »</TD></TR><TR><TD CLASS="quote">racingskittle, don't you have 60 trim T3? those are usualy a standard /stage 1 wheel</TD></TR></TABLE>
yup . Ohh, is there a huge difference between stage 1 and stage 3 for spool? All it is a bigger compressor isn't it?
Or wait. The wheels different too. Now that you mention it....what the hell is the difference?
Re: SOHCs with larger turbos how bad is your lag? Mine sucks! (racinskittle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racinskittle »</TD></TR><TR><TD CLASS="quote">
Or wait. The wheels different too. Now that you mention it....what the hell is the difference? </TD></TR></TABLE>
Smaller wheel = faster spool
Bigger wheel = slower spool
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racinskittle »</TD></TR><TR><TD CLASS="quote">you have a leak or something. Im running a .63 exhaust housing on my T3 and it spools pretty ****** quick. starts at 2000 2-5th gear and hits max around 45-5000. Holds well till readline.
when does it start spooling?</TD></TR></TABLE>
I also ran a .63/.60 t3 on my old setup and it was a perfect compromise, I started spooling a couple psi at like 2500 and I saw 10 psi by 4000 and it held it when I shifted. Now with the t3/t4 it might see a few psi at 3500 and maybe 5psi at 4000-4500.
I have examined pretty thoroughly for any exhaust leaks and dont see any obvious ones. I guess next step will be pressure test the whole system but I am not getting my hopes up. In my experiece I have seen bad leaks (like completely uncapped vaccuum fittings) not cause too much more than a few hundred rpm lag and I dont think I have any that are that obvious unless im totally missing something.
Anybody else have a t3/t4 on a sohc want to share their spool times?
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omahaturbocivic »</TD></TR><TR><TD CLASS="quote">Where the other sohc guys? Post your turbo and when you spool!</TD></TR></TABLE>
Greddy 15G, pretty much spools at idle
*grabs keys to go for a drive*
Ive got a T3 .60/.63 from a nissan.
On a d15 with 10:1 comp and shot rings.
Turbo has blown seals too.
Charge piping is way to0 big at 2.5
Doesnt start to boost until 4500. 5psi right away.
By 5-5500 its at 7 psi. Thats where my wg is set.
2.5 inch downpipe/exhaust.
Re: (sleeping GIANT)
man, all you guys with standard T3 wheels are not doing something right. I can get 11-12 psi at 3000rpm in 3rd with mine.
2.5" exhaust w/ cat, short tubular manifold, bit of extra timing through the boost transition at about 13:1 afr till 2-3psi. I would be pissed if my car only pulled from 5500-7300
Re: (twkdCD595)
wow something doesnt seem right there. im running a t3/t04E granted i have a .48 ar exhaust housing but i see 12psi at 4300rpm. Like previously suggested i would suspect either an exhaust or boost leak somewhere.
wow.....theres definitely a leak or something. once i hit 15psi on my t3/t4b i hold it there every even after shifting. i get like 15psi by 3,500rpms on my SOHC F23, start boosting @ 1,800rpms
Re: (b_ron007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b_ron007 »</TD></TR><TR><TD CLASS="quote">wow.....theres definitely a leak or something. once i hit 15psi on my t3/t4b i hold it there every even after shifting. i get like 15psi by 3,500rpms on my SOHC F23, start boosting @ 1,800rpms</TD></TR></TABLE>
F23's don't apply... he's talkin about 1.6 liters.
