SOHC worth putting boost to?
Is it worth boosting the d16z6? How comparable is a gsr swap in a hatch to a d16 at 7psi? If it's pretty close i may just opt for the gsr swap and boost it down the line.
Travis
Travis
Travis
Travis
If your looking for a lil more oomph and fun driving w/ a decently quick (for a honda anyway) car, turboing the d16 is a good route, especially if you don't want to dump LOTS of money into it and go all out on it. If you're looking for like 300-400+ whp, eventually, I personally wouldn't bother because it take a lot to make a d16 make that kind of power.
Budget also plays a good part. Damn right I wish I could put down 300-400whp, but my budget can't support that anytime soon (19yr old college student.... shitty). If you don't think you want to be dumping thousands into a car, go with the sohc turbo. You said you're thinking about the GSR swap, if you can afford to buy it and boost it go ahead. By all means one of the best choices if u wanna make power. Anyway hope that helps and didn't confuse the snot outta you.
Marc
My 1/4 time goal is 12s. I've heard it's pretty hard to get the d16z6 into that time bracket. What are the realistic times for a stock blocked d16 and turbo? I'm only planning on running 7psi at the moment. What kind of times can be expected with that? My plans were at fist to boost, i may still do so. But if a swap will make about the same power and get me down the 1/4 in the same time or close to i think i would rather have the swap and boost it later. Used bseries turbo kits are everywhere.
I myself have 00 Ex w/ 35k on the motor (bought the car new). I have looked into get a swap then turbo *ls or b20* but then I didn't rule out keeping my for d16.
Reason being:
1- The condition of the motor, with a swap you are unsure of mileage and wear. And if boosting you wanna make sure the motor is solid first.
2- What are looking to do w/ the car, realistic whp/ 1/4 times..
3- The overall cost of your build up.
With swap more pwr is to be made along w/ a nice $$ tag. Same applies to the d16 to a certain point.
Like CivicRyda2K stated it all in what you wanna do and what your budget can afford.
If you're not looking for all-out power, i'd stick with the D-series engine, and turbocharge it. If you want to make huge power (300+ HP) then i'd do the B18C swap, and do the turbo later. The modifications to a D-series will turn out cheaper IMHO.. Grab a set of the piston/rods that i'm making for H-T people (link in my signature), and setup some sort of decent engine management with a blockguard, and you can push 14-18psi daily.
glad to see midwestrider and turbopanda agree w/ me. although jinxproof posted the best combo for making power in a honda:
but,like i said, your budget/goals should determine your decision, not the hype of getting a swap or whatever (seems like that's how it is with some people). If you do it that way, you won't have to worry about dumping all the money into the car when your not that serious or on the other end, dumping all the money into a sohc and ending up w/ a fast sohc but a slow honda
swap to a 95+ b series first. always. turbo second.
Lets just put it this way, if you want something that will be fast on the streets, stay with the d-series. If you want something fast at the track go with a swap. There is a difference between street fast and track fast, on the streets a lot of people will think they are fast because they have a body kit, at the track people know what they are doing and will pound a d-series into the ground (most of the time).
There was a guy on here that hit 12.64 with his SOHC VTEC turbo setup running i think 10psi max in a hatchback, this was a stock motor but the car was definately gutted, i forgot his username. B-series cost money, b-series turbo kits cost even more money but they will net you more power with some work.
good point, if you have no experience with turbos, stick with the d-series for now. Reason being, you will probably break something down the line and getting d-series parts is cheap and easy. B-series are easy to find, but sometimes the price is much higher. Hell, I got a set of brand new crower rods for d-series motor from a guy for like $300, just because they were for d-series and he knew no one was going to pay full price.
yah... it's like this...
d-series motor complete swap $500-600
b-series motor complete swap $2000-3000
just in the money aspect. hands down though if you want a lot of power, b-series is what u want
I'm not looking to be the "fastest" but i want to be quick. At least faster then a ITR. I want to stick with the d-series for the reasons stated above. Everything will have to be done on a budget. The questions is if i want to swap and wait longer to make more power. For the most part i'm leaning toward useing the engine i have now. I figure it will atleast cost me $4000 to go turbo. I can get a ITR engine for $500 more and i can install it myself. I know plenty of people in the 13s with that setup. Keep the comments coming.
Travis
Travis
If you plan on spending $4000 on your turbo setup, you will be faster than an ITR. Assuming you buy good quality parts, besides the sound of a blow off valve is so nice
why go with a swap.
why go with a swap.
within the month i should have my sohc boosted.. yay.... geno, did you figure out hte problem with your car yet?? let me know whenever you want some tuning done...
I'm not looking to be the "fastest" but i want to be quick. At least faster then a ITR. I13s with that setup.
yea I figured it out. This is going to sound dumb, dont flame. I bought my arias pistons used from someone and didnt change the rings when I put the pistons in. Did a compression test and the numbers were sick....pulled the head friday and found that the #3 cylinder had oil puddling in it. Head gasket looked fine, but I am going to change it anyway. I dont think any of the rings really sealed, but I know for sure that the #3 didnt
So I have to order new rings (any suggestions on brand are welcome) and I also got one of the o2 simulators that zip sells. So after I get these parts and get it put back together it better work
I plan on using the Apex kit for my setup. I have a question though. What is involved with adding an external waste gate? I've head nothing but good so far on the apex kit, granted it hasn't been out long. I'm going with that kit for the ball bearing turbo and fitment it suposed to be great. It's a must for me to keep my A/C as well. Does the apex kit sound like a good start?
Travis
Travis
to convert to an external wastegate you need to have the internal flapper welded shut on the turbo, then you have to add a flange to the manifold for the external wastegate to sit.
What other manifolds are compatable with the apex turbo that will allow me to keep my A/C, have good clearance, and have a flange for a external waste gate?
All SOHC kits let you keep a/c thats what i think, i'm not sure on that but most kits do let you keep a/c, why do you want ext. watsegate its not really neccesary for your application.
If you arent building your motor I assume you arent going to try and push this thing past 10psi or so. An internal wastegate is fine for that sort of application. Spend that money on an electronic boost controller so you can raise boost levels and you will be fine.
Yes i do plan on building my motor. At the moment i'm just going to keep it at 7psi untill i'm used to it. I will be boosting over 10psi. I want to build my motor to be able to run 12psi all day. So are there any manifolds compatible with the apex turbo?
