SOHC what to do?
Old Aug 21, 2001 | 10:57 AM
Genedog's Avatar
Default SOHC what to do?
98 civic SOHC (vtec)
I heard a supercharger gives a range of 40-60hp gain is this true? and would adding a zex kit as well with a 45-50 hp shot be overkill? What shoul I change on my engine to take this hit? Any suggestions on parts? I really don't want to swap the engine it only has 16,000 miles on it. Also planning on swapping the stock clutch but I guess what Im looking for is the best ---- but safe way to keep my engine.. with out it blowing on me...
any suggestions would be appreciated............
Old Aug 21, 2001 | 07:52 PM
98 Ek LsVtec's Avatar
Banned
Default Re: SOHC what to do? (Genedog)
look into a motor swap best way to go
Old Aug 22, 2001 | 03:22 AM
4dGSR at work's Avatar
ok jrsc it!
the sohc engine can and has taken about 20 pounds on several passes. Now with the help of nathan.......the silver sohc turbo car w/ toyota pistons you can run 18 psi daily.
here's the deal
get a jrsc and run a 14-16 psi pulley
e-mail me to get the name if the people that make it locally (ny/queens)
they did it b4 on an R and a SOHC.
I am a big fan of the sohc motor. I like the gearing.
the jrsc is great even at 6 psi it will pull on gsr's with I/H/E. My friend's jrsc'd delsol pulled on many. FACT!!!
at 6 psi it seems like it puts down 155whp or more (knowing an integra puts down 145whp about, and my friend had more than a gsr)
....so at 14-16 psi?? maybe 200 or more to the ground
sounds good to me!
Old Aug 22, 2001 | 05:14 AM
Genedog's Avatar
1996+ models are all OBDII compliant and the law only permits same year or newer engine hybrids. I know of too many people that have had their cars confiscated. Engine swap is the best way to go and I agree but Im looking for Ideas for the SOHC. like what pistons to use? etc.
14-16psi seems like a lot of pressure. What changes should my engine undergo..
jasonek98
Jul 31, 2011 09:55 PM
spun Vtec
Mar 6, 2010 01:02 AM
powerls
Jan 27, 2004 01:54 PM
TurBoXBirD16
Jan 20, 2003 04:02 AM
