Sohc Vtec Turbo Problem!
Old Oct 10, 2005 | 09:15 PM
Honda007's Avatar
Default Sohc Vtec Turbo Problem!
My brother has my old setup D16Z6 turbo 16g doing 15psi daily & S200 tuned already with msd ss external coil.
It seems to misfire only at idle and after vtec point. I've tried to gap the plugs down to .25 and it misfires less after vtec point but misfires during idle like once every 40-60 seconds. If I increase the gap to .35 the idle is "perfect" with no misfires at all, but after vtec point it misfires like crazy. I know the bigger gap is getting blowen away but why is the tighter gap still having misfires at idle and after vtec point. If you drive the car without passing vtec no misfires at all only at idle if the gap is .25
Has anyone had this problem?
Old Oct 10, 2005 | 11:12 PM
Drew Peacock's Avatar
Default Re: Sohc Vtec Turbo Problem! (BoostedAsian)
I had a similar problem it was the tune at fault even got the full MSD kit to attempt to fix the problem made no difference it was the tune...
Tighter gap smaller spark harder to ignite the mixture at idle.
Old Oct 11, 2005 | 06:32 AM
LilCivic04's Avatar
Default Re: Sohc Vtec Turbo Problem! (turbozxi)
i thought that tighter gap make stronger spark?
Old Oct 11, 2005 | 05:16 PM
Honda007's Avatar
bump for some help
Old Oct 11, 2005 | 06:27 PM
USDM 4G VTEC's Avatar
take away 1-2 degrees after VTEC
see if that helps
IMO is more tunning related (timing)
Old Oct 11, 2005 | 06:41 PM
Default Re: Sohc Vtec Turbo Problem! (LilCivic04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LilCivic04 &raquo;</TD></TR><TR><TD CLASS="quote">i thought that tighter gap make stronger spark?</TD></TR></TABLE> Less likely to blow out under heavy load but obviously not as big a spark as plugs that have a wider gap.
Old Oct 11, 2005 | 07:36 PM
ExCon's Avatar
Im new to this whole forum scene and i was wondering if anyonw out there could tell me what are ALL the nessesary components for a turbo charged D16Y8.
Old Oct 12, 2005 | 08:49 AM
Jizzmaster Zero's Avatar
(banned)
Default Re: (JDMedEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMedEK &raquo;</TD></TR><TR><TD CLASS="quote">Im new to this whole forum scene and i was wondering if anyonw out there could tell me what are ALL the nessesary components for a turbo charged D16Y8.</TD></TR></TABLE>
Turbocharger, cold air intake, and a Mugen chip. You'll be all set.
Old Oct 12, 2005 | 09:09 AM
nerdsports's Avatar
jacking this guys thread and asking a ridiculous question.
do some research. (ie Forced Induction FAQ)
Old Oct 12, 2005 | 09:30 AM
Honda007's Avatar
Default Re: (nerdsports)
bump
Old Oct 12, 2005 | 10:20 AM
1boostedcivic's Avatar
Default Re: (BoostedAsian)
i had the same problem. it was the gap and perhaps the tune. im gapped at .28 right now. before i was at .32 it was misfiring later in the rpms. if the gap still doesnt solve ur problems, then im willing to bet it was in the tune bro.
Old Oct 21, 2005 | 10:00 PM
YiNYaNg's Avatar
Default Re: (1boostedcivic)
it seems like it's your tune
Old Oct 25, 2005 | 11:21 PM
YiNYaNg's Avatar
Default Re: (H-T)
check your IM's dude!
Bj Le Det
Jan 6, 2017 12:06 AM
jdmsir4dr
15
Apr 6, 2010 04:07 PM
Mr_CRX
Sep 29, 2004 12:01 PM
