SOHC vtec running 7-8 psi
Old Apr 6, 2002 | 07:20 PM
KevronsEG's Avatar
Default SOHC vtec running 7-8 psi
what type of times am i looking at? just try to see if i want to do it.
Old Apr 7, 2002 | 06:11 AM
KevronsEG's Avatar
Default Re: SOHC vtec running 7-8 psi (CIV616)
yes i knew it would be fast
Old Apr 7, 2002 | 06:20 AM
DragII's Avatar
high 14s/low 15s
Old Apr 7, 2002 | 11:18 PM
PyroVTEC's Avatar
New User
Default Re: SOHC vtec running 7-8 psi (SuperDragII)
Yup. Figure around 14.9 or so.
Old Apr 8, 2002 | 03:40 AM
yoshe95si's Avatar
Default Re: SOHC vtec running 7-8 psi (PyroVTEC)
My best was 14.1 but I only had 8psi in my drag radials I had on. The sorry *** track didn't have a tire pump! But I've seen people run high 13s. I've seen a dumped 95CX with a D16Z run consistent 13.5s.
Old Apr 8, 2002 | 04:34 AM
TurbodCX's Avatar
Default Re: SOHC vtec running 7-8 psi (yoshe95si)
i am runnig 18 psi on d16z6 and can consitanly run 13.0-13.1, im so close to the 12's i can taste it,
this is on slicks also
brian
Old Apr 9, 2002 | 04:48 PM
VTC_CiViC's Avatar
Default Re: SOHC vtec running 7-8 psi (TurbodCX)
14.63 @ 95.01mph on 6psi of GReddy intercooled boost
Old Apr 9, 2002 | 05:50 PM
ion_four's Avatar
high 14s/low 15s
Say WHAT?! That's way slow man...or so I hope (working on Sohc vtec boost project, hehe) I'm thinkin low to mid 14's depending on others...if you stripped it and had a computer I'm sure you could break into the 13's...though it would be alot of work for not much boost
Old Apr 9, 2002 | 10:45 PM
JFK78's Avatar
Check my sig.
Old Apr 9, 2002 | 10:51 PM
sushibug's Avatar
Default Re: SOHC vtec running 7-8 psi (ion_four)
high 14s/low 15s
i dunno if thats "slow" because at the track, i lose to my friends gsr by half a second... and that is several car lengths, a bus length or more as a matter of fact... so if you have a 14 second car you should be pretty quick.
r6king28
Aug 14, 2006 06:17 PM
JBOCRXsiR
Jun 18, 2004 03:18 PM
ironcheftony
Jun 24, 2003 12:59 PM
JFK78
45
Aug 12, 2002 04:24 AM
MCNease
May 8, 2002 04:34 PM
