what do yall think i would run?
what do u think id run, the 1/4mile with a fully built sohc vtec and a t3/t4 turbo or bigger in a eg hatchback, boosting 20-30 or watever ?
something like this or bigger
im not down with this homemade tubo setups that cost around 1grand to do
im looking for the MONSTER SETUP!!!! i want to open a can of vtec, nastyyyyy
Re: what do yall think i would run? (ironcheftony)
its all about your driving and at 20-30psi you better be a damn good one.
13's - 11's i guess.............?
i have never seen 30 psi on a SOHC, hope you can pull it off?
Re: what do yall think i would run? (drjondurst)
10's with the proper tuning, driver slicks.. etc..
11-13's if ur on a real tight budget because of the engine build
Re: what do yall think i would run? (maxim)
Could run 15's or it could run 9's. A few important thing we all need to know. What car is this going in? What size injectors? What rods and CR are you going to run? Who's tuning your car? What ECU/standalone are you going to run? What size slicks? What................
It's going to be hard to tell you what you may run. It may be easier for us to tell you what kind of power you could make.
so why did you post pix of TheShocker's setup?
most T3t4 turbos look very similar, its going to depened on what the turbo specs are.
so you wanna opena can of vtec, nassstyy.. then get a dohc!
and 20-30psi... not sure what the limits of GE or most sleeves are ..somthing like 25psi max right?
best of luck with the sohc bro!
comon guys i said FULLY BUILT, darton sleeves, pistons, rods, cams, retainers, springs, valves, EVERYTHING.....
would i not need to boost 20-30 psi ?
im looking for a racer setup, i dont know how to explain, ive read peoples and what they done, its not much just a stock block with small turbo and 15psi
i posted that pic because it was the only biggest thing i could find to a nice turbo setup
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironcheftony »</TD></TR><TR><TD CLASS="quote">im not down with this homemade tubo setups that cost around 1grand to do
im looking for the MONSTER SETUP!!!! </TD></TR></TABLE>
my wack $700 home made kit hit a 13.7@101 in a heavy *** coupe on drag radials.
Re: what do yall think i would run? (The Crow)
do people now the amount of work and effort it takes to make a FWD to run 10's??? with that set-up, you should run 12's......what have you done in the way of driveline? this is fair more important in a FWD drag car then high power engines. if you can't get the power to the ground properly, then you aint going no-where fast! just looking at your list of mods, i'd say you'll run about a mid 12. the T4 is a relatively large turbo so you'll get crazy top end power!!! get some slicks too.
silverb18
09-22-2004 07:52 AM
dscoptato
05-22-2004 07:59 AM
