SOHC Turbo question
Old May 29, 2002 | 02:38 PM
Endless's Avatar
Default SOHC Turbo question
A friend of mine is looking to turbo his D16Z6 and had some questions regarding cams. He's thinking about possibly running a Zex cam but wonders if it's better to run a stock cam when turboing. He'll be using the Greddy kit. I know that some cams can be too agressive for use with a turbo, but I'm not sure if the Zex would be. Thanks for the input.
Old May 29, 2002 | 03:15 PM
inspyral's Avatar
Default Re: SOHC Turbo question (Endless)
Doesn't Crower make a turbo cam?
Old May 29, 2002 | 03:27 PM
sushibug's Avatar
someone on a different forum dyno tested the cams... and no, they dont work good with turbo. he lost 2-3 hp by adding them.
Old May 29, 2002 | 04:37 PM
maxim's Avatar
Default Re: SOHC Turbo question (sushibug)
stock cams are always best, you will be losing power and losing money.
Old May 29, 2002 | 05:30 PM
liam821's Avatar
25 Year Member
I was running 18psi on a stock cam....worked very well. Although i had a friend that gained like 25hp with a JG reground cam running 10psi with a greddy kit...so a good cam can help.
liam
Old May 29, 2002 | 06:02 PM
TurBoXBirD16's Avatar
stock is fine
how much is he getting the turbo kit?
give me an email, i can get u some kick *** price
ywcheung@shaw.ca
Old May 29, 2002 | 10:20 PM
ion_four's Avatar
Default Re: SOHC Turbo question (maxim)
I think that's a little broad I'm sure if you were going to run alot of boost, you could gain alot of power by switching cams, probably to one with less overlap. (which might seem worse in an NA application)
Old May 29, 2002 | 10:32 PM
Trac226's Avatar
Default Re: SOHC Turbo question (ion_four)
I've only run across people using aftermarket cams to either stay at the same hp or lose some. You can always go back to stock after u try them
pryme1022
Jun 29, 2009 08:40 PM
BoostedCivic85
May 6, 2008 02:47 PM
Tuner85
Mar 19, 2007 04:19 AM
skip122
Mar 25, 2005 07:22 AM
4G-CIVIC
Nov 19, 2001 10:53 AM
