sohc turbo question
Old May 19, 2005 | 05:10 AM
killa6776's Avatar
Default sohc turbo question
I have a 90 civic s1 with the d16a6 and im planning on puting a t3 turbo on it (.48/.48) and i was going to run 8 psi, i already have a walbro 255lph fuel pump and an adjustable fpr and a vortech 12:1 FMU and what i need to know is will i need to do anything more for fuel and would i need to do somthing about spark/timing like a msd btm?
Old May 19, 2005 | 05:43 AM
meltman1234's Avatar
Default Re: sohc turbo question (killa6776)
Get some DSM 450's, you can get them for real cheap used. And I would go with something other than the FMU for all your fuel/timing needs. Uberdata is what I use, others use Crome and turboedit. It all depends on what tuners use in your area. Find out what they tune with the best and get that.
Old May 19, 2005 | 07:06 AM
blackeg's Avatar
Default Re: sohc turbo question (meltman1234)
i use uberdata as well, but seeing that you are obd0, id go toward turboedit
Old May 19, 2005 | 07:12 AM
EJ1 wilcox's Avatar
Default Re: sohc turbo question (blackeg)
Since you are OBD0 go with TurboEdit for sure
Do some reasearch on TurboEdit and get rid of your FMU, your engine will thank you for it! It will run smoother, safer, more reliably, and have more power.
kpjo4
Jan 12, 2010 06:42 PM
big_dong861
Dec 17, 2007 08:15 AM
hspoon
Aug 15, 2007 01:17 PM
hahagasdcrx
Feb 2, 2004 11:28 AM
kHoA DoGG
May 14, 2003 11:29 PM
