SOHC Turbo Project
Hey Guys
im thinking of doing a SOHC Turbo or Supercharger project over the next coming months
im not too sure where to start.
turbo or supercharger
stay with the sohc non vtec motor or get a jdm sohc vtec motor then start from there.
i dont have and clue where to begin
little help thanks
little help thanks
i heard alot of good things about the d15b motor from japan its very strong motor for turbo comp is about 9:5 to 1 so the motor will love i would go turbo you can research a bunch of set-ups on basically stock mors except for arp rod and head bolts and maybe a pnp head not to much mods but id go trbo if was you i got a b16 in my coupe prolly gunna go turbo or trade for a sohc turbo motor set-up good luck with wutever you choose
sohc zc powaaahhhhhh! im doing the same thing man with my zc
14b dsm turbo or t25
hf mani
dsm side mount ( using it front mount tho)
dsm 310cc injectors
fmu
etc etc
check out this website for help on sohc turbo
http://www.homemadeturbo.com
hf mani
dsm 310cc injectors
fmu
etc etc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonKid »</TD></TR><TR><TD CLASS="quote">Hey Guys
little help thanks</TD></TR></TABLE>
power goals??
edit: 1100 posts!! woo hoo
power goals??
im doing some pretty serious research
and people are telling me there is no way i can read 300hp or even 200hp?
is that even possible with a sohc d16y7
Modified by SpoonKid at 6:04 PM 9/15/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonKid »</TD></TR><TR><TD CLASS="quote">i dont some pretty serious research
is that even possible with a sohc d16y7</TD></TR></TABLE>people that say that are closed minded. it is very possible. the guy that posted immediately before you just hit 320 on a base tune and is hoping for 500 with race gas. http://www.d-series.org/forums...27329
build your motor right, and it can be done
I'd say go with the JDM motor if you won't be building it. If you will, just find a good Z6 block. Honestly, most sohc's blow because they use stock components. If everyone was to rev <U>stock</U> B16 heads to 10k daily and float a valve, they wouldn't think it's a mfg defect - <U>on a sohc they would</U>.
FTJ has a sohc non-vtec vitara/eagle setup (cheap) with everythign else stock, and he's pulling around 250whp & low-12's in a '00 hatch, full interior. There was a 400whp d16 on here that had a freak accident with a valve floating at 7k (built head), stock sleeves held fine.
For over 200whp, you'll want a good block, arp studs, rods, and maybe pistons. I'm building a 300whp sohc for less than most people put into just a basic b-swap. My only fear is maxing the 450cc's before 300whp
egturbo
48
Jan 19, 2003 06:24 PM
