sohc turbo. finally got it!!! need help with setup
I have a drag 1 turbo kit for my z6 but I dont want to install it until I have everything I need to run it. It has everything, mani, dp, waste gate, bov, fmic, and fmu. Now I dont have a boost gauge yet and would like to know what gauges are more important for turbo use. air to fuel, oil pressure, egt, or what not.
Also I have a rebuilt motor for this, should I break it in first N/A then put the turbo on, or do it all at once and remove the wastegate spring?
i almost forgot. Do i need bigger injectors and fuel pump right away?
i would upgrade my fuel pump and injectors if it was me. Also you should be fine installing it all at once if you take it easy like a normal break in.
Who are you getting to install it? I'm from Richmond too.
I am going to install it myself.
The fmu is temporary until I can afford hondata, but it will work for 7.5 psi. Anything after that will need better tuning.
Am I right? i should have nothing to worry about if I leave it at 7.5 lbs
