smoking on deccel...?
Old Jul 30, 2008 | 10:06 AM
.CUBISH.'s Avatar
Default smoking on deccel...?
having a problem with a fresh motor..
motor only has about 500 miles on it.
new rings, etc
car doesnt smoke at all under load or any other time other then down shifting and letting the motor brake the car
noticed some oil on #3 plug. changed the valve seals on that cylinder and its still smoking.
compression is 190 all the way across. im thinking oil rings.. could it possibly be a guide even though i changed the seals?..
Old Jul 30, 2008 | 11:52 AM
SovXietday's Avatar
Default Re: smoking on deccel...? (.CUBISH.)
Turbo on or no?
Mine does it too, only on extremely heavy decel, doesn't do it any other time. Every Honda I have owned does this though, lol.
Old Jul 30, 2008 | 12:04 PM
.CUBISH.'s Avatar
Default Re: smoking on deccel...? (SovXietday)
no..like its bad..lol
yeah its on boost... i highly doubt its the turbo.. i coulkd be wrong.
ive gone down the street and purposely down shifted hard..came back and pulled the plug out really quick and it had oil on it
Old Jul 30, 2008 | 12:06 PM
SovXietday's Avatar
Do a leakdown? I don't know otherwise, it almost sounds like turbo seals but that wouldn't leave only one plug with oil on it.
Old Jul 30, 2008 | 12:09 PM
.CUBISH.'s Avatar
leak down is fine.. im stumped. going to bolt a stock header on and see if it still smokes..lol
(i really hate pulling this topmount setup off)
Old Jul 30, 2008 | 12:24 PM
SovXietday's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .CUBISH. &raquo;</TD></TR><TR><TD CLASS="quote">leak down is fine.. im stumped. going to bolt a stock header on and see if it still smokes..lol
(i really hate pulling this topmount setup off)</TD></TR></TABLE>
**** dude, topmounts should be easy to pull off besides them weighing a million pounds.
Honestly, if your compression/leakdown tests were good and the car doesn't burn oil during acceleration, I would personally just put up with it. It's that big blue cloud behind you going down the track that sucks.
Old Jul 30, 2008 | 12:38 PM
.CUBISH.'s Avatar
i can handle a little smoke, but this **** is pretty damn bad
Old Jul 30, 2008 | 12:44 PM
tony1's Avatar
What intake manifold? PCV valve?
I had an issue with my car way back when. Put a GSR intake manifold on it (stock) and still had the straight through adaptor on the black box from the LS, not the PCV from the GSR. Fresh motor. Would run fine then sometimes smoke like crazy. lol The oil was filling up in the intake plenum and would slosh around and get down a runner and smoke. Huge relief when i found the problem, i thought something was wrong with the motor.
Old Jul 30, 2008 | 01:05 PM
.CUBISH.'s Avatar
Default Re: smoking on deccel...? (tony1)
running a sheetmetal intake manifold..
nothing from the block running to the manifold. have one of the block holes running to a catch can. still have the black box, but its vented to the catch can also
Old Jul 30, 2008 | 01:12 PM
hotrod99's Avatar
thats really strange...i would have guessed valve seals since it smokes on decel but you said you replaced them so i have no clue...**** like that is really frustrating.
Old Jul 30, 2008 | 01:22 PM
.CUBISH.'s Avatar
Default Re: smoking on deccel...? (hotrod99)
im wondering if it had bad guides with new seals if it would still smoke.. the old motor blew in that cylinder.. put new valves in it, but the guides could have gotten damaged from driving about 20 miles with 2 bent valves
Old Jul 30, 2008 | 01:25 PM
hotrod99's Avatar
well theres only one way to find out...goodluck on getting this problem solved
Old Jul 30, 2008 | 01:29 PM
.CUBISH.'s Avatar
yup.. just dreading taking it all back apart again
Old Jul 30, 2008 | 01:31 PM
CRXdan's Avatar
Mine smokes a bit if letting it idle for a long time then rev it, but I know my valve guides are shot. I put brand new seals in mine as well but knew it woudlnt cut it. If the guide are shot, that seal is useless.
Id bet its your valve guides.
Old Jul 30, 2008 | 01:39 PM
hotrod99's Avatar
Default Re: smoking on deccel...? (CRXdan)
btw is this on your race car or DD?
Old Jul 31, 2008 | 05:19 AM
.CUBISH.'s Avatar
kinda in between. drive it pretty often
not much of a practical daily driver..
2.0 gsr
Topmount
BB T72
500+hp on pump gas
750+ on q16
Old Jul 31, 2008 | 05:36 AM
Turbogixxer's Avatar
You may want to check your valve guide height. I had a problem with a car that did that. It has bent valves before and the machine shop (A VERY good one) installed the valve guides too high so when it hit vtec, it would rip them.
Old Jul 31, 2008 | 05:45 AM
.CUBISH.'s Avatar
Default Re: (Turbogixxer)
yeah im going to tear it apart today and inspect everything..
Old Jul 31, 2008 | 01:53 PM
Turbo-charged's Avatar
Default Re: (.CUBISH.)
sounds like the exact problem i had 2 weeks ago (minus the oil on the plug)
took the turbonetics turbo off (brand new) and put a factory exhaust manifold on it..... all the smoke went away. turbos at turbonetics now for warranty repair. it was on one of those god awful turbonetics b series turbo kits with their supplied feed and return lines. (we didnt do the install but the return line was def. acceptable)
Old Aug 1, 2008 | 05:25 AM
.CUBISH.'s Avatar
Default Re: (Turbo-charged)
yeah jeff was telling me about the turbo u guys were having problems with... took the turbo apart and there is oil on the back plate of the turbine.. have another turbo here im going to throw on and see what happens
Old Aug 1, 2008 | 02:01 PM
srmofo's Avatar
thats valve seals all the way, if the guides are bad it will just tear up the new seals, also it might be more than one cylinder, if thats all you replaced .When turbo seals go bad its usually under hard accelartion or if its really bad all the time.
Old Aug 2, 2008 | 07:32 AM
.CUBISH.'s Avatar
Default Re: (srmofo)
changed the turbo..and sure as **** it stopped smoking.. weird how every simptom lead to the valve seals and they ended up being fine. checked the plugs after a hard deccel and no oil.. dont get it...whatever at least its not smoking anymore
Old Aug 2, 2008 | 08:34 AM
blackeg's Avatar
i have just about the same problem. as soon as my car starts to decel, and for a min after it comes to idle after decel it smokes oil. my compression is 195-200 and leakdown even 10%.
as people said earlier, it could be the valve seals/guides pulling oil into the motor when its pulling lots of vacuum.
Old Aug 2, 2008 | 08:24 PM
Muckman's Avatar
Moderator in Chief
Default Re: (blackeg)
Can a lack of a catch can or PCV cause this?
LSTurbo23
Sep 3, 2011 03:48 PM
acuralovar
Jul 13, 2009 09:16 AM
Hill4589
Apr 10, 2009 04:56 PM
adam1027
Jun 29, 2007 09:26 PM
p0oty
Jul 21, 2002 05:44 PM
