smoke problem
Old Nov 19, 2003 | 08:37 PM
FleXingMyEK's Avatar
Default smoke problem
i just installed my drag turbo kit for my h22 and the car keeps blowing out alot of white smoke, it smoked up the whole street.
where should I gap my spark plugs?
DO I need anything else for this set up?
It's a Gen3 drag kit for the h22 in and 97 civic hatch.
Old Nov 19, 2003 | 08:41 PM
Ri5e's Avatar
Default Re: smoke problem (FleXingMyEK)
Did it smoke right when you start up the car after the installation? Or while driving?
Old Nov 19, 2003 | 08:46 PM
shermanyang's Avatar
smoke is never a good sign, but if it's a new kit, let it run for awhile and see if it goes away. when if first peiced together my kit, it smoked for a few hours before settling in.
Old Nov 19, 2003 | 09:00 PM
Default Re: smoke problem (Dr. Boost)
it smoked right when i started it up.
Old Nov 19, 2003 | 09:03 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FleXingMyEK &raquo;</TD></TR><TR><TD CLASS="quote">it smoked right when i started it up.</TD></TR></TABLE>
mine did the same thing...just let it run for awhile...maybe a few hours and see what happens. check your oil and coolent level at all times and also check your compression to insure that it's not a major problem.
Old Nov 19, 2003 | 09:12 PM
DaveF's Avatar
Default Re: smoke problem (shermanyang)
check the oil return line....
the only smoke should be coming off of them tires(from spinning)
Old Nov 19, 2003 | 09:38 PM
Bailhatch's Avatar
Default Re: smoke problem (2.2Lcivic)
pretty much every car i have put turbo on have smoked a bit at first. Especially if you are using new parts.
k20powered
Honda Civic (2006 - 2015)
36
May 4, 2010 08:03 AM
crxb16a90
Aug 25, 2009 10:24 AM
hdeuce
Jul 19, 2005 08:31 AM
riceburnah
Apr 30, 2003 08:01 PM
JSpecwest
Aug 10, 2001 08:13 AM
