smoke on decel?
Old Oct 24, 2005 | 07:13 PM
iHOPEyouCHOKE's Avatar
* B A N N E D *
Default smoke on decel?
i'm looking at buying a turbo hatch that's on HT. but the owner told me it smokes on decel a little, what could be the cause of that? it's ls turbo, never posted in this forum so i'm not sure what info you guys would need..
Old Oct 24, 2005 | 07:16 PM
heretolearnandteach's Avatar
could be the valve stem seals
Old Oct 24, 2005 | 07:17 PM
* B A N N E D *
Default Re: (heretolearnandteach)
take your 8 post and hit the ******* red X at the top right of the screen and never come back.
Old Oct 24, 2005 | 07:21 PM
AbitAvenger's Avatar
Default Re: (iHOPEyouCHOKE)
My X is kind of grey\black, does this apply to me also??
Somebody help this kid
* B A N N E D *
Default Re: (AbitAvenger)
<- does it look like i'm laughing lol.
Old Oct 24, 2005 | 07:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iHOPEyouCHOKE &raquo;</TD></TR><TR><TD CLASS="quote">take your 8 post and hit the ******* red X at the top right of the screen and never come back.</TD></TR></TABLE>
Why the hell would I do that, sorry for trying to ******* help. When you have weak valve stem seals the vacuum from the cylinders upon decel causes oil to be pulled past the seals and burned in the cylinders. But you knew that right
jrponline's Avatar
Default Re: smoke on decel? (iHOPEyouCHOKE)
this is kinda low tech, but its a good indication.
go up a hill, and then coast down it with the car in 4th/5th gear without giving it any gas.
If it puffs blue smoke when you take it out of gear and give it some gas, your pistons rings are done.
Modified by jrponline at 8:51 PM 10/24/2005
Old Oct 24, 2005 | 07:33 PM
can you put some tech behind that ^^^ so i understand it a little more...
Old Oct 24, 2005 | 07:47 PM
jrponline's Avatar
no problem.
Its the high vaccuum that is caused from going downhill underload that causes oil to be "sucked into" the combustion chamber. So really, it could be your oil control rings, or your valve guides/seals. no way to be sure, other than to dissassemble and check.
Old Oct 24, 2005 | 07:58 PM
Understood...bump
Old Oct 24, 2005 | 08:07 PM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by heretolearnandteach &raquo;</TD></TR><TR><TD CLASS="quote">
Why the hell would I do that, sorry for trying to ******* help. When you have weak valve stem seals the vacuum from the cylinders upon decel causes oil to be pulled past the seals and burned in the cylinders. But you knew that right</TD></TR></TABLE>
you said valve stem seals and that's it, i figured you were being sarcastic (tire stems).. sorry for the mis understanding.
so the smoking could be a problem?
Old Oct 24, 2005 | 08:45 PM
andysila's Avatar
LOL thats funny.
Old Oct 24, 2005 | 09:00 PM
Burke's Avatar
Banned
you said valve stem seals and that's it, i figured you were being sarcastic (tire stems)</TD></TR></TABLE>
lol
Old Oct 24, 2005 | 09:28 PM
bump
Old Oct 25, 2005 | 04:06 AM
m R g S r's Avatar
its the valve stem seals...he's right.
decel is obviously vaccuum. so thats the problem, get the head checked out.
Old Oct 25, 2005 | 07:31 AM
Dunc's Avatar
BCICAN
you said valve stem seals and that's it, i figured you were being sarcastic (tire stems).. sorry for the mis understanding. </TD></TR></TABLE>
haha, I can see that ending up in someone's signature
Old Oct 25, 2005 | 10:29 AM
Root79's Avatar
Default Re: (Dunc)
I have the same problem. At acceleration no smoke. When shift in neutral or let it breaking in 3 or 4 gears the blue smoke shut out of exhaust. Then smoking stops.
Old Oct 25, 2005 | 12:13 PM
Unsivil_audio's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iHOPEyouCHOKE &raquo;</TD></TR><TR><TD CLASS="quote">you said valve stem seals and that's it, i figured you were being sarcastic (tire stems).. sorry for the mis understanding.
so the smoking could be a problem?</TD></TR></TABLE>
lol, I was like "Jesus...does this guy have terrets or what?"
And as for your question, as long as it doesnt smoke on acceleration I think its the valve stem seals. Have someone drive behind you and get on it, that the best way to figure it out. Compression test will tell you what kind of condition your rings are in.
Old Oct 25, 2005 | 01:24 PM
kodirtysi's Avatar
This is really good info, I had the same problem.. turns out it was one of my problems though, have the head checked, and do a Comp test, leak down. good luck.
Old Oct 25, 2005 | 02:06 PM
Civicman86's Avatar
yup i would have the head checked also.
iHOPEyouCHOKE: Sounds like you need chill just a bit. Valve seals and tire stems? Sounds like you need to learn a bit more before messing with FI. $.02
Old Oct 25, 2005 | 02:16 PM
m R g S r's Avatar
Default Re: (Civicman86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicman86 &raquo;</TD></TR><TR><TD CLASS="quote">yup i would have the head checked also.
iHOPEyouCHOKE: Sounds like you need chill just a bit. Valve seals and tire stems? Sounds like you need to learn a bit more before messing with FI. $.02</TD></TR></TABLE>
sounds like YOU do...
tire stems or valve stems are not effected by boost
Old Oct 25, 2005 | 04:48 PM
abnaasefmb's Avatar
Default Re: (m R g S r)
hhhahahahahahaaaaaa ahhahahahhaaaaaaahaah haaaaa!
TOOL.
why do people always seem to jump off w/o thinking. there is this thing right here https://honda-tech.com/zerosearch that can help soooo many!!!
"valve stems"
Old Oct 25, 2005 | 05:59 PM
CivicBwoy's Avatar
lol
funny *** peoples in here
Old Oct 25, 2005 | 06:06 PM
abnaasefmb's Avatar
Default Re: (CivicBwoy)
Here is another insightful post https://honda-tech.com/zerothread?id=1408366
https://honda-tech.com/zerothread?id=1367294
this can't be for real, must be one of those guy that make gag post to get a rise out of people.
G0TB00ST
Apr 2, 2007 09:32 PM
mra4886
Mar 29, 2007 05:59 PM
SlicksMH
Mar 9, 2007 02:14 PM
Turbo-charged
Dec 13, 2005 07:13 AM
CRX 2.0V-T
Nov 30, 2005 12:01 AM
