Smoke?! b16-t?!
From: Sin City to CA, to TX, NC to FL, then back to NC...
okay here's the problem. it's my 99si....grrr... when i'm driving with about 5-20% throttle, the car starts to putter on all gears in between 3000-5000rpms and the needle jumps. then the trippy thing is, sometimes a big *** fire ball pops out as soon as i let off and get on the throttle again. along with it is also smoke. so i look at the egt, it's normal. a/f, it's normal. boost gauge, normal no crazy *** spiking. so wtf!! i check the spark plugs, hella black. so i got myself a new set, still same thing. then i check the friggin snail, oil is starting to come out the intake side.....car has been tuned (a/f 11:5) . i've been running on this tune now for about 2mths and everything has been right since yesterday. here's the setup.
t3/to4x
wastegate set 6.5lbs
440s
vafcII
rising rate fpr
fuel pump
stock internals except sprockets
could it be the injectors? i've had a problem with my efb16 and it was the ignitor wires all coroded. could it be that? please give me an honest input.........thanks
Modified by TnC at 7:56 AM 11/18/2005
t3/to4x
440s
vafcII
rising rate fpr
fuel pump
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@nnY »</TD></TR><TR><TD CLASS="quote">if the tach is jumping around its most likely a distributor problem....bad ignitor</TD></TR></TABLE>
also check your alternator
I missed that
I missed that
hey danny, could it be because the ignitor wires are coroded? i really need my car asap and i'm at work right now yelling at recruits grrr... i'll try to get some pictures on thanks
Who is Mr Robot?
its not the injectors... itsthat damn fmu you are running. its causing you to run pig rich out of and in boost. ditch the fmu and get real fuel management
and congrats your turbo is now **** itself... the compressor side seals are fucked... im betting because its a t04x that its an ssac turbo beacuse only they sell that ****.... figures
