Small problem on decel... Ideas welcome :)
Old Apr 27, 2006 | 06:04 PM
Tactic$'s Avatar
Default Small problem on decel... Ideas welcome :)
Lately, I have noticed that while on decel, with the car in gear, the wideband has been flickering from "air" to "lean" (its the plx300).
For the past two days now, during the same "decel" the injectors are turning on. I get a reading of about 12.5 a/f when it happens. (keep in mind, this happens on decel, in gear)
I throw a CEL when it happens..... I'm thinking TPS? or an injector sticking? Ideas welcome
Setup:
Uberdata (yeah)
440cc RC's
boosted. (im sure this really has nothing to do with it)
Its ran great up until just a few days ago. perfect A/F with exception of this.
-Jase
Old Apr 27, 2006 | 06:10 PM
DaveF's Avatar
Default Re: Small problem on decel... Ideas welcome :) (Tactic$)
any smoke ? white ?
Old Apr 27, 2006 | 06:13 PM
LilCivic04's Avatar
throttle body sticking, try cleaning it. also then reset the ecu. i had the same problem and it seem to fixed it
Old Apr 27, 2006 | 06:15 PM
mike93boost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tactic$ &raquo;</TD></TR><TR><TD CLASS="quote">Lately, I have noticed that while on decel, with the car in gear, the wideband has been flickering from "air" to "lean" (its the plx300).
that's what it is supposed to do.
I throw a CEL when it happens..... I'm thinking TPS? or an injector sticking? Ideas welcome </TD></TR></TABLE>
could be a bad tune.
why don't you check your codes? that would make sense..
Old Apr 27, 2006 | 08:44 PM
Tactic$'s Avatar
Default Re: Small problem on decel... Ideas welcome :) (mike93boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93boost &raquo;</TD></TR><TR><TD CLASS="quote">that's what it is supposed to do.
could be a bad tune. why don't you check your codes? that would make sense..</TD></TR></TABLE>
I don't think that its supposed to flicker back and forth. Never did before. (i've been boosted for over a year now)
Been trying to check the codes. I work 12 hour days, sometimes 7 days a week. I know it only takes a second, but I was kinda hopin the friendly HT community would help out. Thanks for your reply anyways.
Smoke: No. None.
Throttle body: I dunno about this one. The injectors DO shut off on decel, until about 5k, then the injectors come on, the PLX reads 12-13ish, and I get a CEL. Pull over, key out, restart, code gone. Thanks though. You reminded me to clean the TB anyways
I am however going to reset the ECU. Its something that I had thought of too.
Thanks guys. If anyone has anything to add, please do.
Old Apr 28, 2006 | 05:17 AM
Tactic$'s Avatar
Morning bump
Old Apr 29, 2006 | 08:01 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tactic$ &raquo;</TD></TR><TR><TD CLASS="quote">I don't think that its supposed to flicker back and forth. Never did before. (i've been boosted for over a year now)
on what you described and what i quoted and replied to.. YES that is what it does on decal when you let off the gas. it is normal. and i dont care if youve been boosted for 20 years, youre still a dumbass.
Old Apr 29, 2006 | 08:03 PM
Tactic$'s Avatar
Modified by Tactic$ at 9:32 PM 4/29/2006
Old Apr 29, 2006 | 08:10 PM
Tactic$'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93boost &raquo;</TD></TR><TR><TD CLASS="quote">that is what it does on decal when you let off the gas. it is normal.</TD></TR></TABLE>
Care to explain why this is, smart guy?
Old May 5, 2006 | 08:59 PM
Tactic$'s Avatar
Still having the problem. Any help?
Old May 5, 2006 | 10:27 PM
dpetro1's Avatar
tell us what CEL you are getting and then we will be able to help you.
it is normal for the wideband not to have a reading on decel, because when you let off the gas the injectors turn off.
Old May 6, 2006 | 04:27 PM
LilCivic04's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tactic$ &raquo;</TD></TR><TR><TD CLASS="quote">Lately, I have noticed that while on decel, with the car in gear, the wideband has been flickering from "air" to "lean" (its the plx300).</TD></TR></TABLE>
well when your off the pedal, it should go to "lean" then to "air." thats normal man. i've been driving way over a 2 years on my plx-m300.
Nighthawk R18
Honda Civic (2006 - 2015)
13
Jan 7, 2008 06:41 PM
civic46
May 7, 2007 12:30 PM
kim_2_da_chee
Feb 17, 2005 11:05 PM
PowderB16
10
Sep 27, 2004 03:15 PM
WAFFLES
Apr 25, 2003 01:42 PM
