Slick size!!! help please....
Old Apr 18, 2006 | 04:06 AM
JDM97R's Avatar
Default Slick size!!! help please....
Hi guys,
Recently I have put a B18C turbo into a civic ef.
The engine has about 360whp and with a jdm 98 spec tranny.
Now i use slicks m/h 24.5/8/15 and i have till second gear spinning at the drag strip,and did ET 11.1 with 1.91 60" .I have also the skunk 2 drag launch. I have a set of m/h 26/8.5/15 and was going to try them.Btw , i cross the line in fifth gear.
What do you think guys? should i try the bigger slicks?
The car +driver weights about 1050kg.
Thanks guys
Old Apr 18, 2006 | 06:29 AM
Zakar's Avatar
thats fast for only 360whp..
Old Apr 18, 2006 | 08:43 AM
raene's Avatar
Default Re: Slick size!!! help please.... (JDM97R)
1.91 is a horrible 60' time for 24.5" slicks, I was pulling 1.73s on 22" slicks. You should be in the 1.6 range. What do you have for suspension work?
Old Apr 18, 2006 | 08:53 AM
Mugencrxsir1's Avatar
Default Re: Slick size!!! help please.... (raene)
What was your MPH?
Old Apr 18, 2006 | 08:58 AM
turbo*s2k's Avatar
24" should be fine... Try lowering the tire pressure some more.
Old Apr 18, 2006 | 11:35 AM
JDM97R's Avatar
Default Re: Slick size!!! help please.... (TurboChrgd_Civic)
As suspension ,i have the skunk 2 drag launch.My mph is 127mph
Old Apr 18, 2006 | 12:27 PM
JDM97R's Avatar
Anyone please
Old Apr 18, 2006 | 01:08 PM
raene's Avatar
What do you have for tire pressure, and how do you do your burnout (be descriptive). If you have a vid that will help!
Old Apr 18, 2006 | 10:51 PM
JDM97R's Avatar
Tyre press i keep them 10 psi cold and burnout ,i do it on second gear
Old Apr 19, 2006 | 08:06 AM
raene's Avatar
Are you pulling out of the waterbox when you do your burnout or remaining in it? Sounds like you've got the pressures about right. How long do you burn out for?
Old Apr 19, 2006 | 11:43 AM
JDM97R's Avatar
Yes i get out from the water box.I keep it for about 5 to 8 seconds
Old Apr 19, 2006 | 12:41 PM
raene's Avatar
Is the track not prepped? For some reason it doesn't seem to be hooking off the line since you say you're spinning heavily. Are you sure you're not roasting the clutch maybe?
Old Apr 19, 2006 | 02:04 PM
postman's Avatar
maybe lower the rpms off of launch
Old Apr 20, 2006 | 11:27 AM
JDM97R's Avatar
Default Re: Slick size!!! help please.... (postman)
As a clutch i have a 6 puck clutchnet.The track is well kept with grip juice and everything.I should try to launch at lower revs maybe at 5000
Old Apr 20, 2006 | 02:45 PM
s2kdre's Avatar
u need to come out of the hole at like 7500rpms, ur probably bogging thts why ur pullin 1.9's
b18cej2
Apr 29, 2009 01:57 PM
christion
Jul 7, 2007 02:00 PM
Samuels
Feb 5, 2007 02:57 PM
vw1320
Aug 26, 2006 12:15 PM
JDM97R
Apr 18, 2006 12:05 PM
