sleeves keep cracking
Old Aug 13, 2002 | 04:48 PM
AznInvasion's Avatar
Default sleeves keep cracking
my friend has a b18c1 in his 93 hatch with je 9:1 pistons bored 20 over and stock everything else with tuned hondata 2b and running 15psi. He cracked the sleeves twice already and was wondering why its happening?
Old Aug 13, 2002 | 04:50 PM
93LSivic's Avatar
Default Re: sleeves keep cracking (AznInvasion)
hmm, i wonder ..........15psi and .20 over. Those walls are kinda thin for 15 psi.
Old Aug 13, 2002 | 04:53 PM
Pinhead's Avatar
New User
Default Re: sleeves keep cracking (93LSivic)
yea, usually if you wanna boost 1 bar you should get 81.25 max with stock sleeves, just my opinion
Old Aug 13, 2002 | 05:58 PM
Pwerdr's Avatar
The sleeves are cracking to detonation which probably means bad tuning. What octane are you using?
Old Aug 13, 2002 | 06:06 PM
PrecisionH23a's Avatar
Re-sleeved blocks can handle this though, correct??? I have dartons with a 25 overbore and will run 18psi with the hondata 4b fully built EVERYTHING as well as 720cc's, will i have sleeve cracking problems as well?
Old Aug 13, 2002 | 06:19 PM
Pinhead's Avatar
New User
Default Re: sleeves keep cracking (GudeH23a)
not with descent tuning, you shouldn't have a problem at all...
Old Aug 13, 2002 | 06:23 PM
Smashback's Avatar
Default Re: sleeves keep cracking (Pwerdr)
I don't think you should assume that without seeing the guts first.
Old Aug 13, 2002 | 06:26 PM
AlphaKennyWun's Avatar
I dont think you will crack Dartons. They are so totally different than stock sleeves.
k-cerez
15
Nov 25, 2004 08:59 PM
Turboteggy
Jan 13, 2004 07:28 PM
BoostedD15B7
Apr 7, 2003 04:32 PM
speedy108
Jan 8, 2003 07:52 PM
The Punisher
Aug 26, 2001 07:46 PM
