which sleeves are better?
Old Jul 20, 2012 | 09:37 PM
conertedrange's Avatar
Default which sleeves are better?
just curious which sleeves i should go for im hoping to push around 500-600hp whats the benefits or lack there of on mid, dry and wet sleeves and whats the differences in them?
Old Jul 20, 2012 | 09:50 PM
TheShodan's Avatar
Moderator
Default Re: which sleeves are better?
Golden Eagle would be best (Not dry or wet) but ductile Iron goodness.
I'm just waiting for a CSS argument..
Old Jul 20, 2012 | 10:05 PM
rico892002's Avatar
i think there all good, golden eagle is one of the best on the market, alot of people dont really like open deck sleeved blocks and there some that do..still trying to find out who i want to go with.
Old Jul 20, 2012 | 11:14 PM
are you talking about open decks as in the h22a4? and what would you say is the reason why people dont? I heard open decks can and or do overheat more/easier?
Old Jul 20, 2012 | 11:19 PM
Hyper16-Johnny's Avatar
Which ever you can get cheaper! I've had Benson's, Darton, AEBS, Golden Eagle and LA Sleeves and they all work well. It's all in your clearances and tuning that keep the motor lasting. So in my honest opinion, which ever is cheapest.
Old Jul 21, 2012 | 06:46 AM
SPOOLINmatt's Avatar
yep, the lowest bidder for sure lol.
Old Jul 21, 2012 | 07:44 AM
ok, thats what i figured but im known for being a penny pincher so because of that i didnt want to go by price hahaha!
anyways thanks guys I appreciate it!
Old Jul 21, 2012 | 09:44 AM
92redhatch's Avatar
I had ERL do my sleeves. GE are cheap and people make good power on them also. I wouldn't waste my time on a block guard or CSS.
Old Jul 21, 2012 | 09:48 AM
phaphon's Avatar
I have a benson sleeve block and I haven't had any problems with my sleeves
Old Jul 21, 2012 | 10:11 AM
grumblemarc's Avatar
The Grumpiest
Adamantium. Sorry. I couldn't help it.
Old Jul 21, 2012 | 12:34 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
I would beg to differ. Anything "Golden Eagle" I have laid my hands on is inferior quality... things may have changed, but I doubt it. Also, the Darton Sleeves are the BEST in a true race enviroment. They provide diesel like cylinder swapping. To each his own.
A sunk sleeve is strictly from installation error or a bad block (which should have been spotted by the installer).
Old Jul 21, 2012 | 01:48 PM
TheShodan's Avatar
Moderator
10 years on the same GE sleeved block, and 67 events.. Nah..I'll stick with the GE. One place to install, one place to yell at if there's ever a problem.
Old Jul 21, 2012 | 04:49 PM
kranked91dx's Avatar
I did a few build on GE sleeve, good stuff.
I did quite a few build, about 5, on Darton sleeve, good stuff too.
I personally own a Benson block, built by Earl Laskey at the time... Good stuff, never had an issue with it, doing 540 Whp on race event, with Race fuel.
Like it was said before, cheapest bidder with the job... as long as it ductile Iron, and the installer is a professional, you will not have a problem with those 3 manufacturer.
But remember... Piston to wall clearance, on boosted application is critical, as is Ring Gap and Bearing clearance on crank and rod, Oil pressure is a serious thing to keep on check too.
good luck !
Kranked
Old Jul 22, 2012 | 05:20 AM
Wanchai's Avatar
I use golden eagle, But if i gonna build more i will go with ERL.
The reason both of my GE block needed to be line horn.That cost time and money.
Old Jul 22, 2012 | 06:37 AM
Someone needs to create a sleeve design where the engine builder can replace single sleeves in their own shop with typical shop tools!
Old Jul 22, 2012 | 08:29 AM
DO IT ON ALL FOURS
Uhhh... Darton Wet sleeves are as close as you are goong to get...
Old Jul 22, 2012 | 09:10 AM
jdm inc's Avatar
all sleeves are good!
been on Golden eagle for quit some time now and zero issues!
g.e. ftw!
Old Jul 22, 2012 | 07:01 PM
hybrdthry911's Avatar
I have a personal preference for benson because I've had 3 blocks built by them and never had any issues at even beyond 900whp. I like the fact that is it an open deck which promotes great cooling at the top of the cylinder, this may or may not be negligible but it makes me feel good inside. This is my favorite sleeve for a street car for this reason. On the contrary some say the open deck promotes instability in the sleeves, but I have never heard of anyone having issues.
GE would be my other choice. A few buddies have their sleeved blocks and also had no issues. I have heard all success stories. I'm not sure about the need for align honing the GE blocks, but I always prefer to stay away from line honing a honda block to keep oil pump clearances in OEM spec.
Old Jul 22, 2012 | 07:13 PM
Hidenplanvew's Avatar
Line hone affecting oil pump clearances.. Please inform me on how this works
I have used la sleeves one 3 of my blocks and I love them. They make sleeves for one of the other big name company's or supplies blanks for them or something of the nature.
Old Jul 22, 2012 | 07:14 PM
TKERacer619's Avatar
ERL did my block and another gsr block along with it. My block came back fully assembled, line honed, and full of metal shavings. I was a seriously pissed off customer.
The sister block sunk a sleeve.
I wish I had better stuff to say about ERL but they definitely dropped the ball when it came to my motor and its sister engine. If the shop I purchased the work through didn't have their mechanic do a complete tear down and clean out it would have ended up in court.
The motor has held up and is making good power but damn they sent me an assembled block full of Metal shavings!!
Old Jul 22, 2012 | 07:31 PM
a1320addict's Avatar
lmfao
Old Jul 22, 2012 | 07:56 PM
DO IT ON ALL FOURS
Line boring moves the crankshaft centerline. It is not a big deal as all you have to do is shave the oil pump alignment dowels to get even clearance all around the pump gear/crank snout.
Old Jul 23, 2012 | 12:38 PM
90dxhmt's Avatar
I would be more concerned with who is installing the sleeves then with the brand. I used LA sleeves but any of the big names will work.
Old Jul 23, 2012 | 04:50 PM
trickeng's Avatar
Originally Posted by a1320addict
lmfao
Really??? Your not even smart enough to know your shop is 100ft from a river during a flood yet you leave customer product on the floor. Not once, but twice. I bet all the customers you screwed weren't laughing there *** off.
Almost 4years of proving the CSS process. Any complaints??? Anyone??? Come on just one person who is unhappy with there CSS??? Its funny to see how angry the haters get without having one complaint to through in my face. Not even one!!!
conertedrange: I'll tell you right now the CSS process will work perfectly for your 500-600hp application and ensure that your sleeves don't crack. Also keep in mind that the CSS will allow cooler cylinder temps than any ductile iron sleeve (open or closed deck) because of the superior heat transfer of alum compared to iron. This is huge for street cars. All for less than 1/2 the price of ductile iron sleeves.
Old Jul 23, 2012 | 07:53 PM
I'm lost here!?
I got a reputable place I'll be going through for the machine work part of the build. I guess I'm more wondering about what the differences are between the dry mid and wet sleeves and advantages if any at all
what is the css process and do you know or have any write ups or dircetion to some details on it?
