Sleeved b16
Have to switch areas of ht for this I was going allmotor but need a little more *** than 200whp. It's a very basic setup 84mm 11.2:1 Manley pistons, eagle rods, acl bearings, balanced, gsr head, ported, bronze guides, gsr cams, and have not decided on what valvetrain yet between Manley and ferrera, ge intake manifold, Wilson 80mm tb, efi wizard 1000cc injectors and either a 6262 or the 5758 don't know yet but that's about it. I'll post the pics of the machine work so far later tonight.
Sounds like a really good set up.
That 84mm bore and 11:1 C/R will help spool that 6262 a lot better than a normal B16 bottom end.
Make sure you get a really good tune though because of the C/R.
I would say your goals are mild given the set up your working with.
I would think 450 whp on 93 should be no problem.
Depending on what your running for a fuel set up, getting to 600+ whp on C16 should be attainable as well. You will just need a dual fuel pump set up and bigger injectors.
Good Luck!
Good Luck!
Mach1n1st
142
Nov 5, 2021 02:29 PM
slowsleeper
28
Oct 16, 2008 10:31 AM
