sleeved b16?
Old Oct 15, 2008 | 01:29 PM
dragdatzu's Avatar
Default sleeved b16?
so ive come across a deal on a brand new sleeved b16.......my question for you all is can i make decent horse power and torque on a reasonable amount of boost......i just dont see many sleeved b16 block out there......and could i see some of your set ups? k thanx
Old Oct 15, 2008 | 02:41 PM
yakuza's Avatar
Default Re: sleeved b16? (dragdatzu)
If you want torque then mostly everyone will tell you to go B18 or B20, alternatively if its sleeved then bore it to something like 84mm.
I'm running a darton sleeved B16 but so far just running 6psi on conservative tune. Seems to putting decent power as I managed 150mph and it still kept pulling but not very impressed with my turbo as too laggy for me and gets full boost around 5KRPM.
Set your power goal and what type of drive you're after wether its daily drive, track, 1/4 mile, etc then you can determine what's the best setup for your application.
Old Oct 15, 2008 | 07:22 PM
dragdatzu's Avatar
TTT
Old Oct 15, 2008 | 09:06 PM
crxfreak1117's Avatar
just got my sleeved b16 block back from golden eagle about a week ago and now i have about 70 miles on the motor it made right at 400hp on 17lbs then cracked a sleeve here is pics of the new sleeved motor
Old Oct 16, 2008 | 08:35 AM
yakuza's Avatar
Default Re: sleeved b16? (crxfreak1117)
400!! @ the wheels or fly? What turbo is that? I'm not sure if I want to continue with the current 57trim 63 a/r I got right now!!!! Fancy something that would have full spool by 3000/3500 RPM instead of 5K...
Old Oct 16, 2008 | 10:20 AM
Default Re: sleeved b16? (yakuza)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yakuza &raquo;</TD></TR><TR><TD CLASS="quote">400!! @ the wheels or fly? What turbo is that? I'm not sure if I want to continue with the current 57trim 63 a/r I got right now!!!! Fancy something that would have full spool by 3000/3500 RPM instead of 5K...</TD></TR></TABLE>
i have the same turbo and thats at the wheels
but what kinda power are u wanting to make?
Old Oct 16, 2008 | 11:11 AM
LastGenEK's Avatar
I like the late spool but im 100% street drivin
Old Oct 16, 2008 | 11:25 AM
yakuza's Avatar
I was initially aiming around 250-300whp but after having completely rebuilt my engine I found now that my setup is capable of 400-500whp. The problem is that there is no where to go fast, there's traffic about everywhere you go and even on the motorway drivers pull out on you without telling how fast you're coming.
So it might be more usable on the long run to have something that goes from 0-100km in 5 seconds or less rather than something that can achieve 300km/h ...
Old Oct 16, 2008 | 02:07 PM
swapit's Avatar
See sig for numbers
Old Oct 16, 2008 | 03:27 PM
HiProfile's Avatar
If you get a smoking deal on a sleeved B16 (like $4-500 total), it will be a great motor for 600whp+. Otherwise for a street car, a stock-sleeve B18 will be the way to go. If you really want sleeves, I'd suggest you save your money a little bit, then get a B18 sleeved to 83-84mm. 12.5% more displacement helps in every department, especially with a built cylinder head. You can run 84mm, but torque is made much easier with a larger stoke than with a larger bore.
BTW the only reason you should want to make your power at a "reasonable amount of boost" is if you're running pump gas, at which point you'd really want a larger motor. With a smaller motor you just toss more pressure at it until the turbo gets maxed out.
IMO using a 1.6L block with aftermarket sleeves is like choosing non-vtec over a dohc vtec head. Its not much more in the grand scheme of things, but will let you make much more power.
Old Oct 16, 2008 | 03:58 PM
dragdatzu's Avatar
well the deal is 800 for a brand new jge sleeved b16 with new eagle rods and new moly 12 to 1 pistons which i was gonna sell.....i wanted to do a gsr but this deal seems pretty worth it.....btw i have already been through two stock sleeved gsr blocks that where both destroyed due to a cracked sleeve.....i dont wanna do that again lol
Old Oct 16, 2008 | 05:00 PM
urbansi's Avatar
Yeah thats a good deal, i DD my boosted B16 and rip the **** out of it daily. Do it its a good deal...
Old Oct 17, 2008 | 11:18 AM
dragdatzu's Avatar
ttt
master honda tech
Aug 24, 2005 09:32 AM
xDicktonesx
May 17, 2005 01:53 PM
fernancivic
Sep 29, 2003 02:37 PM
SpdFrk
Aug 29, 2003 07:42 AM
sleepercivic
Oct 22, 2002 07:37 AM
