sleeve or not.
Old Nov 5, 2009 | 01:10 AM
TommyMAn's Avatar
New User
Default sleeve or not.
hi, i have a Accord CD7 with H22a swap done to it.
now its time to boost it...
im goin for 400hp in the motor.
the question is, do i have to sleeve it?
or is it enough with new pistons n valves ect. ?
thanks
Old Nov 5, 2009 | 09:51 AM
TommyMAn's Avatar
New User
Default Re: sleeve or not.
no one?
How much hp does h22 handle with stock cylinder walls?
Old Nov 5, 2009 | 10:28 AM
NonovUrbizniz's Avatar
Loved
https://honda-tech.com/search.php?searchid=5145409
https://honda-tech.com/forums/showth...&highlight=h22
Search dude there are 2000 threads on this
Old Nov 5, 2009 | 10:50 AM
atec's Avatar
We have done 362whp on bonestock h22 engine, that is stock sleeves, and stock pistons etc.
And 321whp on a high comp JDM H22 engine.. both held fine..
If you can get semi forged pistons that will work with the FRM sleeves the h22 has, do that and get a decent tune.
The worst thing that can happend is really a valve drop. it will totally ruin your engine, while a cracked sleeve is just about replacing pistonrings and the block itself.
Old Nov 5, 2009 | 01:20 PM
Turbo-LS's Avatar
400-500whp on stock sleeves is fine with a good tuner, any more than that your pushing the envelope.
Old Nov 6, 2009 | 07:45 AM
TommyMAn's Avatar
New User
ok, i am goin to install new forged pistons and valves, springs. and i have Hondata S300.
so i am on the "safe" side with good tuning..
but i`ve read that if i change to forged pistons, i also have to change Sleeves too...
btw, i have searched.. so im no noob at that..
have been member on hondasociety since 2006..
my car
Old Nov 6, 2009 | 08:27 AM
Turbo-LS's Avatar
you do not have to change sleeves just have to overbore the cylinders 0.5mm over stock size basically buy a pistons that is .5mm larger than stock and bring the block to a reputable machine shop and have the cylinders bored/honed to matc the piston with at least a .0030 ptw
Old Nov 6, 2009 | 09:11 AM
Sales@Bisimoto.com's Avatar
sent you a pm with some info on pistons for you if you choose not to sleeve the block
Old Nov 6, 2009 | 10:17 AM
Loved
my car
I really wouldn't worry about touching the valves or springs... it's just not required for the power you want.. I mean if you have money to burn then definately but if you're trying to be cost effective then I wouldn't bother...
Also as mentioned above you can get VERY close if not to your goal on a BONE STOCK block... maybe it would be better to wade in and just turbo the motor as is and see if you really want to up the boost/power from there... then you can decide if you want to rebuild the bottom end.
I spent a summer in Stavanger on the west coast of Norway (my mother is from Oslo) Beautiful coastline and AMAZING girls!
Good Luck.
Old Nov 6, 2009 | 10:31 AM
CerealKiller's Avatar
Ain't the tolerances of forged pistons and the FRM sleeves different?
Old Nov 6, 2009 | 10:38 AM
Golden Eagle's Avatar
you should never run a forged piston in a frm block they need to be sleeved to run forged pistons. mahle does make pistons for frm blocks thats what you should use if your not going to sleeve it. if you decide to use the forged pistons and not sleeve it good luck because it will not last
Old Nov 6, 2009 | 05:30 PM
LudeLooker's Avatar
Golden Eagle speaks the truth, I would not even consider trying for 400whp on stock block, it's not the sleeves that are the problem on H22's it's the ringlands, and I wouldn't expect to make more than 300whp on one stock, above that I would expect the ringlands to crack in no time, and if your going to boost it you will eventually want more power so honestly I would just sleeve it and do it right, otherwise you might have fun for a while with the stock block but eventually it will fail
Old Nov 6, 2009 | 09:45 PM
DA TeG 90's Avatar
after 500whp is when I would start to think about sleeving. Golden Eagle, Benson, Dartion are what most use on here. I chose to go with Benson sleeves, but what ever you want really.
eg_h22
Jun 3, 2009 01:48 PM
O RLY
Aug 30, 2005 03:31 PM
95blackegcoupe
Feb 28, 2005 08:11 AM
forcefedh22
Feb 27, 2005 04:54 PM
Power Rev Racing
Sep 30, 2004 05:09 AM
