Sleeper gauge locations
i didnt use a nice pod like u tho. looks good
[Modified by Pengo, 12:09 AM 7/19/2002]
Yeah, I like that spot too. I just dremeled an autometer single a-pillar pod until it fit up there flush and went to town. In Integras, there's a little vinyl piece not too big at all that's part of the center console. I really think some company could make some money selling replacement vinyl covers for gauges to be put there.
What kind of materials do you guys use to locate these gauges? Like is that plastic or something that you cut out to place your gauges in DIN slots? I want to place my AVC-R where my factory radio was, but I need to know what you bought.
The ABS works well and is easy to manipulate but the carbon fiber panels are a nice touch that not everyone has....plus no one ever believes that I hand layed the carbon fiber myself.
I'll post a pic..once I find one.....hmm, I can only find an old one with the Autometers installed.
[Modified by SLPR, 8:17 AM 7/19/2002]
you can lay carbon fiber using 2 pieces of glass.
Apply resin on the fiber and smooth it out on the glass getting rid of the bubles. THen sandwich it with the other glass...when it dries..whalllaaa carbon fiber sheet.
how did you learn to lay carbon fiber, is there special tools you need?
For flat sheets I suggest using "new" plexi-glass sheets instead of glass sheets. New plexi will have a similar surface finish as the glass, but the removal of the cured carbon sheet is easiler. All you have to do is flex the plexi and the carbon sheet will pop off. Plus glass can break and make a mess of your workspace.
I can make other suggestion for needed tools and some tips. IM me if you wish.
i wonder if i could buy a sheet of carbon fiber and cut out a slot pretty clean ? How do you get the carbon fiber or abs plastic to mount in the din space with a tight fit, just cut it accordingly, or something else ?
check ebay !!!!!! theres a guy on there with these panels but hold off until i get mine .. so far im gettin pretty bad service, the ****** sent me the panel to the wrong address, it got sent back to him, and he hasnt contacted me since regarding the issue, but he has fairly decent feedback ..
just cuz you guys are lazy http://cgi.ebay.com/ebaymotors/ws/eB...tem=1875243473
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1875242689
check the sellers other items .. he has more for other cars also ..
[Modified by project dc2, 3:40 AM 12/24/2002]
i'm not sure if it was already said...
but radio shack sells these "hobby boxes" that can easily be dremel'd or exacto bladed(kind of).. i'm just using my jdm eg audio console to hold em.
Here's the one in my car...
Its very nice, because now there aren't two tachs in the car, and also unless you really look for it, or are practically leaning through the drivers window, you won't see the gauge there... it's also well within your vision as a driver... very easy to see
pain in the **** to get in there though.
[Modified by HXMan, 4:39 PM 12/29/2002]
Can anyone give me some more info on the HKS Camp? What kind of cars will it work with, what do you connect it to, since they don't make it anymore does anyone make something similar, etc. Would it work on a car with sequential speed pro?
As far as stealth gauges goes, I made a pretty nice pod for my mustang before. I used a single gauge A-pillar pod as a mould and made a cluster of 3 gauges that held boost, fuel pressure, and nitrous pressure
where could a panel of cf be purchased?
or
where could u get the materials to lay the cf?
ive had a few projects ive watned to try with it...thanx
or
