Sleeper gauge locations
Old Jun 16, 2002 | 08:22 PM
  #26
pagong's Avatar
Default Re: Sleeper gauge locations (Quaalude)
I like how you did yours better i shouldve covered it with something ,but, i was thinking that nobody else is going to see it so i just left it at that!!
Old Jun 16, 2002 | 10:33 PM
  #27
dmotoguy's Avatar
Default Re: Sleeper gauge locations (pagong)
in my eclipse i have A/C contols that are circular shaped, i'll get some pics, but i am in the process of putting a/f, egt, and fuel pressure in them.. and i am getting oil and nitrous pressure on the top of my dash
Old Jun 17, 2002 | 07:20 AM
  #28
justagsr's Avatar
I see you used a plexiglass face plate but how did you cut it without it cracking.
<------my problem
tia
Old Jun 17, 2002 | 07:41 AM
  #29
PrecisionH23a's Avatar
Default Re: Sleeper gauge locations (CivicRacerGSR)
probably a dremel tool
Old Jun 17, 2002 | 07:54 AM
  #30
enigmaspeed27's Avatar
Nice set up in the gloveyyyyy
Old Jun 17, 2002 | 08:58 AM
  #31
servion's Avatar
Default Re: Sleeper gauge locations (enigmaspeed27)
Here's my setup in progress
Old Jun 17, 2002 | 09:41 AM
  #32
turbopanda's Avatar
Default Re: Sleeper gauge locations (servion)
I don't like your setup very much.. You should have angled the panel which you have your boost meter an A/F meter on, to the same angle as the outer edge around that area - that boost meter would be almost impossible to read during driving!
Old Jun 17, 2002 | 10:14 AM
  #33
done's Avatar
Default Re: Sleeper gauge locations (inspyral)
If you have an empty DIN panel, you can fit 3 gauges there...
BLITZ makes a 3x43mm DIN panel
Omori makes 3x45mm and 3x52mm DIN panels:
[Modified by inspyral, 11:27 PM 6/12/2002]
who makes those gauges???
are those gauges any good???
What gauges do i need? say i went turbo, what gauges are recommended?
[Modified by Jordo, 1:16 PM 6/17/2002]
[Modified by Jordo, 1:26 PM 6/17/2002]
Old Jun 17, 2002 | 10:28 AM
  #34
inspyral's Avatar
Default Re: Sleeper gauge locations (Jordo)
Omori http://omori-na.com/
I would get at least a boost gauge and an EGT or A/F meter...
Old Jun 17, 2002 | 10:36 AM
  #35
turbopanda's Avatar
here's pics of my friend's 200SX HKS glovebox bezels and HKS Camp unit..
seems like the glovebox thing is the popular thing to do, although it would probably be hard to look at during driving unless you had the meters angled like as shown above..
Old Jun 17, 2002 | 11:16 AM
  #36
Rain_man's Avatar
New User
Default Re: Sleeper gauge locations (turbopanda)
What is that thing that allows you to have an lcd show your gauges?
Old Jun 17, 2002 | 02:13 PM
  #37
Quaalude's Avatar
Default Re: Sleeper gauge locations (GudeH23a)
dremel ....i got my money worth out of this tool, especially with the turbo install and what not
the only problem with cutting plexiglass with the dremel is that the plexiglass will melt and reform, holding the piece you are trying to cut together....u have to cut a small section and then break off the old melt/reform plexiglass and move on
[Modified by Quaalude, 6:15 PM 6/17/2002]
Old Jun 29, 2002 | 01:49 PM
  #38
turbopanda's Avatar
Default Re: Sleeper gauge locations (DarksideDC4)
its called an HKS CAMP.. check it out at HKS' website..
Old Jun 29, 2002 | 02:11 PM
  #39
93LSivic's Avatar
You can also find the HKS Camp on ebay. If you read through the description of the ones sold on ebay, you will see these are stripped down models.
Pretty cool though. Kinda Skyline R34-esq.
Old Jul 16, 2002 | 09:31 PM
  #40
IgniteTeg's Avatar
Default Re: Sleeper gauge locations (93LSivic)
For all of you who put them into the glovebox how do you guyz actually monitor that thing and drive at the same time!
Old Jul 16, 2002 | 09:51 PM
  #41
SiRkid's Avatar
Default Re: Sleeper gauge locations (IgniteTeg)
lol..and not have it bouncing up and down while booting it!?????
Old Jul 16, 2002 | 09:52 PM
  #42
KekeK-18's Avatar
Default Re: Sleeper gauge locations (Teg4e)
sleeper gauge locations= non function locations
Old Jul 16, 2002 | 10:01 PM
  #43
JM Performance's Avatar
Default Re: Sleeper gauge locations (KekeK-18)
mine:
Old Jul 17, 2002 | 06:38 AM
  #44
Pengo's Avatar
that isnt necessarily true. put a gauge in the left center vent angled towards the driver. this all depends if u have enough room, but if u do it works. u can adjust the sections of the vent until u have a clear view of the gauge. turn the adjusters shut and it disappears. voila. sleeper location that is well within ur sight that no one else can see
Old Jul 17, 2002 | 06:47 AM
  #45
Canuk_SiR's Avatar
Default Re: Sleeper gauge locations (Pengo)
here's my gauge locations. There are 2 in the a pillar, and I made a pod out of the cup holder insert for the EGT.
Old Jul 17, 2002 | 06:59 AM
  #46
justagsr's Avatar
Thanks for the info. I had the same problems and that damn plexiglass smells when it melts then hardens. I kept cracking the plexiglass when I tried to cut inserts for my gauges.
Which attachment did you use?
thanks.
Old Jul 17, 2002 | 07:08 AM
  #47
VTC_CiViC's Avatar
Default Re: Sleeper gauge locations (justagsr)
What kind of materials do you guys use to locate these gauges? Like is that plastic or something that you cut out to place your gauges in DIN slots? I want to place my AVC-R where my factory radio was, but I need to know what you bought.
Old Jul 17, 2002 | 07:19 AM
  #48
X2BOARD's Avatar
Default Re: Sleeper gauge locations (VTC_CiViC)
I know that ABS plastic is one of the essential materials used by car stereo installers for a custom install... I assume some of you have used that... but Where in the world do you buy it ?
Old Jul 17, 2002 | 08:28 AM
  #49
pub's Avatar
pub
Default Re: Sleeper gauge locations (Canuk_SiR)
I can still see it fine located here when I look at it. But it's not in my vision the whole time so that crapo a/f gauge doesn't bother me the entire time I'm driving.
Old Jul 17, 2002 | 10:48 AM
  #50
justagsr's Avatar
I used plexiglass that I bought from Home Depot to re-do my DIN slots in my car to hold a different stereo since the aftermarket kits wouldn't fit.
