is skunk2 stage 2 can to big for my set up
im runin turbo in my 90 crx si .. it has acautoworks ramhorn 3 in dp percision sc34 60 ar cold and 63 hot. my question would be is cam to big 4 myset up. this is all on a jdm b16 81mm pistions stock crank stock head with crower valve train.
Re: is skunk2 stage 2 can to big for my set up
They are way too large for that size turbo. The largest I would go with either a 57 or 60 trim are the tuner stage 1 cams. I have seen good results with the stage 2 cams on t67 and larger turbos, but they do not offer any midrange gains compared to the pro 1's. We really only sell either the tuner 1 or pro 1 skunk cams anymore to our customers, and 90% of the time we sell the tuner 1's because they are a drop in cam that requires no cam gears, heavy seat pressure valve springs and give another 20-30whp at higher boost levels over the itr/ctr cams.
