Which sits higher( or lower ) in the deck?
Old Oct 26, 2009 | 07:31 PM
boosted91crx's Avatar
Default Which sits higher( or lower ) in the deck?
if you take a b18c1 block and put a ls crank and ls rods in it with a set of oh lets say cp 9-1 pistons , and then take the same block and pistons and swap in a gsr crank and gsr rods which combo would have the piston sitting higher in the deck? im trying to sort this out since the ls crank has a longer stroke yet its rods are shorter so does it equal out or will one combo sit lower? thanks for the info in advance.
Old Oct 26, 2009 | 11:12 PM
civic_r87111's Avatar
Default Re: Which sits higher( or lower ) in the deck?
They will both come up flat on the deck since the LS and the GSR use the same deck height's. The GSR might b .002" lower..
Old Oct 27, 2009 | 03:50 AM
thanks for the info
Old Oct 27, 2009 | 12:20 PM
Gizz-R's Avatar
Ive read before that throwing all LS components in a GSR will acutally act like a stroked GSR motor. Since the stroke on a gsr is 87mm and an LS is 89. hence more torque
Old Oct 27, 2009 | 02:33 PM
yeah it is a OEM stroker kit so to speak of, i decided to go with the GSR crank and rods so the "stroker" kit is for sale.
Old Oct 27, 2009 | 04:22 PM
HiProfile's Avatar
The extra stroke is taken care of from shorter rods, so it's all in the piston or block.
Then the blocks are different, enough to be noticable, by .55mm/.022" (gsr is taller). If they are the same pistons, the GSR will be .55mm deeper. OEM LS pistons have a 30.00mm compression height, and GSR's have a 30.05mm.
That's probably another reason people get into trouble with LS/V setups, they can end up a point higher in CR in an LS block vs a GSR block with the same pistons.
Very nice calc to estimate compression ratio ----> http://www.zealautowerks.com/bseries.html
Old Oct 27, 2009 | 04:36 PM
well the problem ended up being some one in the past had zero decked this benson block and then it was decked more again and now that i own it its decked so far the pistons stick 25 thou out of the hole.. i had to order a cometic 60 thou head gasket to give me 35 thou piston to deck clearance. the funny thing is we only took 4 thou off teh deck meaning the last owner had to be 21 thou out still, take into consideration a stock style gasket is only 26 thou and that means he had a 5 thou piston to deck!!! i blamed the LS crank and rods and switched to the GSR but it ended up sticking up the same. i said heck with it and just assembled it with the GSR stuff and am selling the LS stuff.
bigbadboy
Aug 28, 2006 06:20 PM
electric_rex
Dec 5, 2004 02:57 PM
mrbsponge
Jun 21, 2004 10:17 PM
EH2LS
Apr 29, 2004 08:24 AM
advanracing62
Oct 11, 2003 09:57 PM
