Simple BOV question...
Old Mar 11, 2004 | 11:44 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Simple BOV question...
This is the deal, im puttin a DSM T25 on my SOHC EG hatch..
should be alot of fun, im almost ready.. i made my downpipe, got the special fitting for the oil line, and just finished making my own custom "log style" manifold.
so this is my question, as for the blow off valve part of the set up, i found this cheapo BOV from the local turbo shop for 50 bucks.. they put pressure to it and it worked, but what exactly does the allen head, or bolt on the top of the valve do? controll pressure? how should it be adjusted? further down the faster response?
check out my blingin BOV.
Old Mar 12, 2004 | 06:17 AM
Nick7's Avatar
Default Re: Simple BOV question... (Built B16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built B16A &raquo;</TD></TR><TR><TD CLASS="quote">
It adjusts at how much VAC it'll open.
Old Mar 12, 2004 | 06:46 AM
Muckman's Avatar
Moderator in Chief
If you find that you have a vacuum leak from the bov you can adjust that **** thingy.
Old Mar 12, 2004 | 07:02 AM
Happyman's Avatar
Default Re: Simple BOV question... (Muckman)
Actually I believe it just adjusts how sensitive the bov will be to open/close. Meaning when your at low boost if you have that **** set to a harder setting it won't blow off. I know my RFL is set to a pretty soft setting and even at like 1-2 psi I can hear it going off. Its not as loud as say 5-10 psi but it's still audible.
Old Mar 12, 2004 | 08:41 AM
JM Performance's Avatar
Default Re: Simple BOV question... (Happyman)
am i seeing stuff or is your bov hooked up to the inlet of your turbo?
Old Mar 12, 2004 | 08:54 AM
RGAZ's Avatar
New User
Default Re: Simple BOV question... (00SilverLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00SilverLS &raquo;</TD></TR><TR><TD CLASS="quote">am i seeing stuff or is your bov hooked up to the inlet of your turbo? </TD></TR></TABLE>
Yeah I see that too. I hope that was just for picture taking.
The **** is for adjusting the spring pressure on the diaphram. Tighter means higher pressure required to Blow off looser means possible leaky valve or very low pasi Blow-off. Basically, loosen it until you can hear it blow at full boost, then tighten it down a bit from there. It will then blow under any throttle release.
randy
Old Mar 12, 2004 | 11:24 AM
Built B16A's Avatar
Default Re: Simple BOV question... (RGAZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RGAZ &raquo;</TD></TR><TR><TD CLASS="quote"> Basically, loosen it until you can hear it blow at full boost, then tighten it down a bit from there. It will then blow under any throttle release.
randy</TD></TR></TABLE>
exactly what i was looking for.. and yes.. the BOV mounted on the compressor is just for kicks.. heh
autowrench07
Aug 23, 2008 06:13 PM
turboteg95
Sep 2, 2006 09:50 PM
14bcoupe
Mar 1, 2005 01:03 PM
v63000gtv6
Dec 30, 2003 10:05 AM
echo999
May 14, 2002 08:54 PM
