SideWinder 2 OverKill?
Old May 4, 2005 | 01:17 PM
  #26
FormulaGSR's Avatar
Default Re: SideWinder 2 OverKill? (Napoleon Dynamite)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Napoleon Dynamite &raquo;</TD></TR><TR><TD CLASS="quote">
If you showed maybe an ounce of gumption and checked out his site, you'd see that it is </TD></TR></TABLE>
http://www.lovefabinc.com/inde...id=10
thats all i saw on it. and it would be more initative (sp?) than gumption
Old May 4, 2005 | 01:37 PM
  #27
Lucky_Smurf's Avatar
Just waiting for mine to show up.
84mm golden eagle sleeves
9.8:1 gsr
fully built head
t3/67
I'm pretty excited to see what this thing can do.
Old May 4, 2005 | 01:48 PM
  #28
Archidictus's Avatar
Unceasing Measure
Default Re: SideWinder 2 OverKill? (FormulaGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FormulaGSR &raquo;</TD></TR><TR><TD CLASS="quote">and it would be more initative (sp?) than gumption</TD></TR></TABLE>
True .
Old May 4, 2005 | 01:57 PM
  #29
_entropy's Avatar
thats all i saw on it. and it would be more initative (sp?) than gumption</TD></TR></TABLE>
gump·tion (gmpshn)
n. Informal
Boldness of enterprise; initiative or aggressiveness.
Guts; spunk.
Common sense.
Gumption = initiative.
Must have been thinking of one-fab that had it listed on their site, or maybe even someone else. I'm sure he could make a 3" quite easily though, but if all you want is a 3" downpipe WHY run the sidewinder V2? Run a minime, done.
Old May 4, 2005 | 02:48 PM
  #30
97 accord se's Avatar
I'd like to know if it's Compatiable with accords and preludes as well?
I'll CERTAINLY be getting this for my LATE future turbo build. Looks crazy and bet it sounds just as nice
Props on the work
Old May 5, 2005 | 06:40 AM
  #31
Tinker219's Avatar
I'm sure he could make a 3" quite easily though, but if all you want is a 3" downpipe WHY run the sidewinder V2? Run a minime, done.</TD></TR></TABLE>
Exactly, save a lil bit of $ if you ONLY want the 3" DP
Itll work in the accords/ludes if you ditch your front motor mount AND build a custom Xmember that resides 6" in front of the motor. I would advise the use of the SideWinder V1, which has become rather popular this past year as well. Sales were down last year so I pulled it off the site, but thats going to change here rather soon! The V1 will fit with only building a custom upper radiator hose to clear everything.
Old May 5, 2005 | 07:29 AM
  #32
Ri5e's Avatar
Default Re: SideWinder 2 OverKill? (Tinker219)
woah, that is way out yonder
Old May 5, 2005 | 07:41 AM
  #33
Tinker219's Avatar
Default Re: SideWinder 2 OverKill? (TurboSmart)
you can thank the starter on the H series for that!
Old May 5, 2005 | 08:06 AM
  #34
done's Avatar
that is said to be one of the best manifold styles. It holds boost perfect.
Old May 5, 2005 | 08:20 AM
  #35
downeyballz's Avatar
Default Re: SideWinder 2 OverKill? (Jordo@KAP)
i would be conserned with the weight that manifold would add. love fab uses so thick *** piping. and it could get heavy really quick
Old May 5, 2005 | 09:13 AM
  #36
Tinker219's Avatar
Default Re: SideWinder 2 OverKill? (downeyballz)
we can make thin wall too, schedule 10, 1/4" flanges, whatever the customer needs
"Ounces make pounds, tenths makes seconds.."(sport compact car), and 100lbs = 1/10th in the quarter. It all comes down to cost and comprimise.
Old May 6, 2005 | 04:34 PM
  #37
ildknyli's Avatar
Default Re: SideWinder 2 OverKill? (dasher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dasher &raquo;</TD></TR><TR><TD CLASS="quote">
Not to get into all the advantages and disadvantages of that manifold but make sure you ceramic coat it inside and out!!</TD></TR></TABLE>
Why would you need to coat inside and out??
Old May 6, 2005 | 04:41 PM
  #38
lsdhatch's Avatar
Where does the oil return line go with all that piping in the way? Do you have any pics?
Old May 6, 2005 | 04:43 PM
  #39
dasher's Avatar
Default Re: SideWinder 2 OverKill? (ildknyli)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ildknyli &raquo;</TD></TR><TR><TD CLASS="quote">Why would you need to coat inside and out??</TD></TR></TABLE>
Long pipe= lots of surface area= lots of heat loss
I'm running a sidewinder V1 which is ceramic coated inside and out and my engine bay temps are really high.... V2 has longer piping, so....
... don't get me wrong, they are great manifolds, I'm just trying to make a point that you would have to be insane not to ceramic coat it.
Old May 11, 2005 | 11:16 AM
  #40
Tinker219's Avatar
Actually, the surface area of the V2 is roughly equal to that of the V1, so it shouldnt produce much more heat. The 4" downpipe theoretically shouldnt get as hot as a 3" either because less restriction=less pressure to cause heat transfer. We are talking a few degrees here, but just shooting theoretical stuff out of my ****.
Heres one we just finished, I believe these are the first "manifold only" shots on the net yet:
NICE and close to the block
Old May 11, 2005 | 11:49 AM
  #41
EJ1 wilcox's Avatar
Wow!
A top-mount-side-winder
What are the advantages of this design?
Old May 11, 2005 | 11:53 AM
  #42
Tinker219's Avatar
Default Re: SideWinder 2 OverKill? (EJ1 wilcox)
wastegate priority design, 4" downpipe WITH AC, need I say more?
Old May 11, 2005 | 12:28 PM
  #43
m R g S r's Avatar
Default Re: (JRciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRciv &raquo;</TD></TR><TR><TD CLASS="quote">and obviously that's not the case because it's made to be A/C compatible.</TD></TR></TABLE>
hey...ya never know...doesn't the summit drag car have a stereo in it?
Well i forgot which team did, but one of em does.
Old May 11, 2005 | 12:30 PM
  #44
m R g S r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 &raquo;</TD></TR><TR><TD CLASS="quote">wastegate priority design, 4" downpipe WITH AC, need I say more?</TD></TR></TABLE>
ya...looks like the WG will get some direct exhaust gasses...should help for boost spike
Old May 11, 2005 | 12:38 PM
  #45
rioninja's Avatar
Hey Cody,
do you have any pics of the sidewinder 2 from the top? Kinda like a birds-eye view.
Old May 11, 2005 | 02:08 PM
  #46
STHPERFORMANCE's Avatar
Default Re: SideWinder 2 OverKill? (rioninja)
Looks good cody..
Old May 12, 2005 | 06:40 AM
  #47
Tinker219's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rioninja &raquo;</TD></TR><TR><TD CLASS="quote">Hey Cody,
like this?
Old May 12, 2005 | 07:18 AM
  #48
sqad_7's Avatar
that manifold is clean!!!
Old May 12, 2005 | 07:33 AM
  #49
Si Shane's Avatar
Default Re: (97 accord se)
It looks like a WRX manifold and upppipe
Old May 12, 2005 | 08:23 AM
  #50
CRXDrew's Avatar
looks like you got mail in that turbo . Great looking design.
