shuts off when hot
Old Aug 20, 2012 | 05:33 PM
Dynasty21's Avatar
From: Where We Squeeze 1st N Ask Questions Last, CA, USA
Default shuts off when hot
Just recently finished my turbo build.
Car shuts off when hot, when I let it sit (its cooling down) it starts right back up until it hits a certain temperature and shuts off again.
Relocated my battery to the trunk
P28 with Hondata S300
GM 3 bar MAP
Anyone experience this or know why this is happening?
Update:
As it sat for 6 hours waiting for tow, the car wouldn't start anymore. No lights on #2 key position.
Old Aug 20, 2012 | 05:45 PM
munster87's Avatar
Default Re: shuts off when hot
It kinda sounds like it's an ignition problem. Check your igniter and coil in your distributor.
Old Aug 20, 2012 | 07:35 PM
Dynasty21's Avatar
I'll check that...
Now been sitting for 3 hours and still won't start. There's no dash lights when I put the key on number 2 position, nor do I hear the fuel pump.
Old Aug 20, 2012 | 07:39 PM
titan101's Avatar
Check your ground for your battery/fuse box.
Old Aug 20, 2012 | 08:00 PM
Dynasty21's Avatar
Where's the ground for the fuse box under the hood? One wire is on the engine harness, the other is straight to battery cable.
Old Aug 20, 2012 | 08:39 PM
titan101's Avatar
Do you have a solid ground connection since you relocated the battery? I had the same issue.
Old Aug 20, 2012 | 09:44 PM
ninjaturtleEG's Avatar
Originally Posted by Dynasty21
I'll check that...
If theres no dash lights when key is in position, then my guess would be the ignition switch.
Old Aug 21, 2012 | 12:30 AM
Dynasty21's Avatar
You had the same issue that when the car gets hot, it shuts off? It's grounded near the taillights with a nut and bolt.
I was thinkin of changing the whole key cylinder but it worked/works when the car cools down, except for tonight. So maybe.
Old Aug 21, 2012 | 05:24 AM
crvtectim's Avatar
Sounds like your chassis ground is flawed. Did you make sure to sand all the way through paint and primer at your connection? My battery is in the back as well on my CRX and I hooked my ground to where my spare tire tie-down would have screwed in. Works great!
Old Aug 21, 2012 | 04:51 PM
munster87's Avatar
I would also check your main relay
Old Aug 22, 2012 | 07:09 AM
turbohatch96y7's Avatar
Have you checked any of your fuses?
Old Aug 22, 2012 | 10:14 AM
Dynasty21's Avatar
What do you mean go for airflow cooling?
No, I haven't checked the fuses.
Updated my original post.
Old Aug 22, 2012 | 10:31 AM
crvtectim's Avatar
Old Aug 22, 2012 | 10:59 AM
Since your battery is in the trunk there should be an inline fuse before the fuse box.
Check for continuity from the positive side of the batt to the fuse box.
If you don't have a multi meter then your wasting time go buy one.
Old Aug 22, 2012 | 11:06 AM
If you were cranking your motor a lot you were drawing a lot of current from your batt.
Your starter draws a lot of amps as is, add in your 6ft of battery cable and the fact your battery voltage dropped during this ill bet 100 bucks you blew your 80amp fuse in the fuse box.
Old Aug 22, 2012 | 07:16 PM
Dynasty21's Avatar
Ground is good, made sure of it.
So still no lights on # 2 even when its been sitting. Checked all fuses under dash and under hood. Where is this 80 amp fuse you're talkin about?
I have a turbo timer installed, when I go from #2 to off, instrument lights turn on (i also hear the fuel pump) and the timer starts counting down. I then decided since there's instrument lights now I turn it all the way to crank and starts right up. The timer is still counting down. Once I put down the handbrake (this is a safety/security feature of all or most timers so noone can drive your car without putting the key on #2) everything shuts off as if I didn't put the key in to go drive.
I took the timer off and plugged back everything without the timer, still no lights.
So since #2 lights come on when the timer is engaged, it can't be the ground wire, there are no blown fuses, not the main relay either. Now what?
Old Aug 24, 2012 | 11:37 PM
Dynasty21's Avatar
Updated
dings35
Honda CR-V & Element
May 27, 2013 06:23 PM
1990GSB18a1
Sep 22, 2012 06:06 PM
Tip14
Dec 27, 2007 01:13 PM
R-81DC2
Jun 5, 2007 09:21 AM
96SIR
Dec 19, 2006 08:08 PM
