should i spray or boost
Old Nov 24, 2006 | 07:33 PM
illassek9's Avatar
Default should i spray or boost
i have a b16 in a eg hatch im planning to go on spray or boost which do yall think is going to be the best for everyday use
Old Nov 24, 2006 | 07:41 PM
BoOsTeD C1's Avatar
boost = no refills
Old Nov 24, 2006 | 09:03 PM
Top Ramen's Avatar
Default Re: (BoOsTeD C1)
If money is not the reason you are considering N2O, then go with boost.
Old Nov 24, 2006 | 09:04 PM
HamiltonRex's Avatar
Default Re: should i spray or boost (illassEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by illassEG6 &raquo;</TD></TR><TR><TD CLASS="quote"> best for everyday use</TD></TR></TABLE>
Turbo anyday my friend.
Old Nov 24, 2006 | 09:36 PM
b20em1's Avatar
Default Re: should i spray or boost (HamiltonRex)
boost!
Old Nov 24, 2006 | 09:40 PM
ek99's Avatar
Default Re: should i spray or boost (b20em1)
boost, you wont regret it
Old Nov 24, 2006 | 10:33 PM
sloganish's Avatar
boost and nitrous ftw
Old Nov 24, 2006 | 11:07 PM
grndcont's Avatar
n20 git's old quick.
Old Nov 24, 2006 | 11:39 PM
turbod da's Avatar
BOOST u never run out and never have to refill
when u need it! just squeeze the throttle.
Old Nov 25, 2006 | 12:07 AM
Schister66's Avatar
Man U FTW
the ONLY thing nitrous is good for IMO is spooling a big turbo....other than that, i wouldnt ever use it
Old Nov 25, 2006 | 02:03 AM
JDMs1eeper's Avatar
r u feeelin lucky! both!
jk
boost *
sorrry had a fwe to drink tonight
Old Nov 25, 2006 | 12:51 PM
aaronISthrowed's Avatar
Default Re: should i spray or boost (JDMs1eeper)
Boost
Old Nov 25, 2006 | 02:08 PM
bigbadboy's Avatar
they are both great but boost is there all the time. there are both good. it just depends on wat you want to do. i use both
Old Nov 25, 2006 | 06:14 PM
Fitti's Avatar
GO WITH BOOST
It will give you more flexiblity. You will be able to adjust the horsepower on the fly with a boost controller
Old Nov 25, 2006 | 07:07 PM
not2slo128's Avatar
Default Re: (Fitti)
both.
good luck.
Old Nov 28, 2006 | 11:48 AM
illassek9's Avatar
Default all motor
i think im just going to go all motor i found out that i can make good times on the track with my motorif i build for all motor with out all the problems of boost and spray
Old Nov 28, 2006 | 12:11 PM
Fitti's Avatar
Default Re: all motor (illassEG6)
what kind of times are you actually shooting for?
Old Nov 28, 2006 | 12:17 PM
ProjectDarkBlack's Avatar
Default Re: all motor (Fitti)
fast all motor cars have just as many if not more problems. Fast boosted cars are just silly, and cheap if you know what you are doing
Old Nov 28, 2006 | 12:28 PM
Mugencrxsir1's Avatar
Default Re: (sloganish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sloganish &raquo;</TD></TR><TR><TD CLASS="quote">boost and nitrous ftw</TD></TR></TABLE>
Yeap, if you have the money, boost your engine, then add a small shot of nitrous to eliminate lag time.
Old Nov 28, 2006 | 05:53 PM
mcclure's Avatar
boost!!!
Old Nov 28, 2006 | 06:07 PM
ATYPR's Avatar
I've been doing that for two years on my daily driver.
If I had to pick one, I would say turbo.
Old Nov 28, 2006 | 06:15 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by illassEG6 &raquo;</TD></TR><TR><TD CLASS="quote">i think im just going to go all motor i found out that i can make good times on the track with my motorif i build for all motor with out all the problems of boost and spray </TD></TR></TABLE>
all motor? as in just intake/header/exhaust? or all motor as in spending as much money if not more as you would on FI. don't let that stuff fool you. any high hp setup comes at a cost. and all motor imo is more headaches. you really have to work for every hp. you can't just turn up the boost
Old Nov 28, 2006 | 07:15 PM
JDogg's Avatar
BOTH!!
Old Nov 28, 2006 | 07:34 PM
Boostfed's Avatar
New User
I like HairSPRAY it makes my hair all hard ewwww. It does need refills every so often so expensive!
Old Dec 2, 2006 | 05:00 PM
illassek9's Avatar
13.0S
