should i sleeve it or not?????
Old Jan 4, 2010 | 06:09 PM
Dlamazing's Avatar
Default should i sleeve it or not?????
ok ht i got a eg with a gsr in it b18c1 i took out the motor took the motor completly apart! head off oil pan pistons and rods i cleaned the block i replaced the water pump,oil pump rear main seal timing belt tensioner got all new oem gaskets everything oem honda parts i just got manley rods for it and cp pistons 81mm and arp head studs the cars not gonna be a daily but mabe take it out once a week to rip on it at the races a bit my goal is 500hp on e85 on boost so since i have it apart i want to know if i should sleeve it or not??? i see some ppl dont have issues on stock sleeves pushing them hard i dont plan on running at full boost all the time for 500hp just know i can use it if i have to let me know whats your opinion thanks for the help
Old Jan 4, 2010 | 07:23 PM
civicjunkie17's Avatar
Default Re: should i sleeve it or not?????
why would you get 81mm pistons for a gsr motor?
Old Jan 4, 2010 | 07:31 PM
95civhb's Avatar
^^ as opposed to 81.5mm?
If the block is honed, I don't see a huge issue.. Most guys will run 81.5, but if the block is good, what's the trouble?
OP: If you have the budget safe > sorry
Just my $0.02...
Old Jan 4, 2010 | 07:32 PM
Boosted-EH-804's Avatar
I would sleeve it if you got the cash for it
Old Jan 4, 2010 | 07:38 PM
Dlamazing's Avatar
well its a stock block hasent been honed had factory pistons in it 81mm so i got 81s for it yah i was thinking the same to sleeve it just wanted to see what ppl think i mean i dont want to spend the $ to sleeve it if i can get away with it since cars not gonna drive that much since i got another car as a daily just need rip on it every once a while
Old Jan 4, 2010 | 10:01 PM
thumper64's Avatar
there are people running a fair amount of power on stock blocks, more than what I'd think would be streetable. Just run it until you wear it out and then resleeve it.
Old Jan 5, 2010 | 06:26 AM
Dlamazing's Avatar
thnx bump
Old Jan 5, 2010 | 11:14 PM
sloturbohatch's Avatar
you will be fine with e85 just tune, tune, tune
Old Jan 6, 2010 | 01:49 PM
DA TeG 90's Avatar
I would sleeve it. Safe > Sorry
Old Jan 6, 2010 | 02:00 PM
LS-turboner's Avatar
ya people are pushin 4oo+ whp with stock sleeves easily. it can be done. people underestimate stock honda blocks, but if its apart, you have the money, why not sleeve it.
Old Jan 6, 2010 | 03:40 PM
taurian's Avatar
i was wondering the same thing? i am also running a t3/t4 b18b1 set up fully built but the funds are low for now, so was wondering on a daily driver how would it be, safe or not?
Old Jan 6, 2010 | 05:54 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
gringoteg's blown up quite a few stock gsr blocks usually cracking the sleeves, hes manking around 450whp so I would say def not a bad idea. plus you can go 84mm if you wanted and make a little more low end.
lil_foy
Dec 20, 2012 07:45 AM
mysterysktr7
Oct 8, 2009 02:13 PM
CivicSI2009
Apr 28, 2009 03:21 PM
boostedb1810psi
May 28, 2007 07:22 PM
GsDAteg
May 29, 2006 04:47 PM
