should i run coolant lines
Old Dec 8, 2002 | 05:37 PM
spooled b16's Avatar
Default should i run coolant lines
I have a b16a2 in a 92 hb with a t3/t4 turbo and so on. I have both oil cooling and water or coolant cooling capabilities on my turbo only the oil is hooked up. Is the coolant that important i've been running it for a few months now. One of my buddies with a sohc ran the coolant lines on his and his engine temp. went sky high. I've heard it can help the turbo's life, but is it worth it to increase the engine temp.?
Old Dec 8, 2002 | 05:51 PM
Farnsrocket's Avatar
Default Re: should i run coolant lines (spooled b16)
I don't know about the engine temps getting hotter.......where did your friend run his coolant from????? My temps remained the same after I hooked mine up......I would say it can't hurt.......all it can do is help your turbo....your friends story is a little odd.
Old Dec 8, 2002 | 06:04 PM
Optiks.'s Avatar
why not get a small radiator or even a trany cooler or oil cooler off of a truck a smaal pump and let the turbo have its own cooling method?
Old Dec 8, 2002 | 06:22 PM
rice a rona's Avatar
It is fine to run without the coolant lines. They are the exact same turbos...just one does have the access to be cooled with water as well. I had the same problem once with the engine temps going up with using the coolant lines on the turbo. It was because the radiator was not capapble. I changed the radiator and it solved the problem. But long story short, you dont need to run them.
Old Dec 9, 2002 | 09:10 AM
RAWB's Avatar
I've been running just oil for over 2 years- cause that's all I got
If you got it- use it(coolant fittings, that is)
philliedawg
13
Feb 8, 2010 07:29 PM
rice a roni
Nov 9, 2006 09:06 AM
RTW DC2R
May 14, 2006 03:01 PM
MooreBoost
May 19, 2004 05:06 AM
This One
Jan 14, 2004 06:06 PM
