Should I retorque head studs??
Old Aug 11, 2003 | 10:24 PM
dualknuttz1's Avatar
Default Should I retorque head studs??
Here's my story: Two months ago I installed a cometic 2mm head gasket to prep my motor for forced induction. I used arp head studs and torqued them down to 70 ft. lbs with the moly lube. the day of the install, I performed a compression test and it was about 210 on all four. I broke in the headgasket for about 800 miles before I installed the turbo. Well, it's been two weeks after I installed the turbo and I noticed the overflow tank leaking with coolant. I kind of ingnored it and continued to drive. It got real bad when I could smell it from the cabin.
I asked around and people told me it could be a possble blown/leaking headgasket. So i performed another compression test today and the outcome was 195-195-175-175 (ish). I looked into the overflow tank and saw no signs of oil. My oil level is a bit low and sometimes when I stop at a red light I can see small signs of white smoke follow and pass me. I read a post the other day and it said that one of his studs backed out. So I was thinking I might retorque the head to like 80 ft. lbs to see if that would seal the head better. Anyone have any suggestion of what I should do. I am low on cash and don't want to buy another head gasket (not OEM cause my CR will be too high).
Old Aug 12, 2003 | 12:56 AM
ScrapinSi's Avatar
Default Re: Should I retorque head studs?? (dualknuttz1)
retorque them to the OEM Specs, not tighter... Some of the bolts may have come loose... if not, you might have popped a head gasket...
Old Aug 12, 2003 | 01:44 PM
Flamenco-T's Avatar
Default Re: Should I retorque head studs?? (ScrapinSi)
Did you use moly lube or regular oil ? ARP wants you to check the torque and re-torque it to the same specs if it's not after 10 heat cycles. This only applied to brand new studs
stan
Old Aug 12, 2003 | 03:26 PM
Default Re: Should I retorque head studs?? (Flamenco-T)
Yeah i bought the head studs new but I dont recall the instructions telling me to heat 10x cycles. I did use the moly lube supplied with it and torqued them down to 70 lbs. I think thats why my overflow tank is overflowing. The head lifted overtime and caused a leak between the head and the block. I have over 1000+ miles now on the motor, in which 300+ is boosted miles. I better do this asap. thanks for the info guys
porkchop-gsr
Aug 26, 2012 05:01 PM
Red-Rag-B18
Aug 23, 2010 05:33 PM
JTCdudeman
Sep 29, 2005 05:42 AM
Rhythm
Aug 7, 2005 09:42 PM
AzG35
Nov 15, 2002 07:37 PM
