should i put a block guard?
Old Nov 20, 2002 | 01:45 PM
Turbo_Teg's Avatar
New User
Default should i put a block guard?
We'll I just pulled out my motor to put in my new one. just stock gsr block with b16 head. Since the head and block are not put together yet, should i add a block guard? What blockguard do you guys recommend?
[Modified by Turbo_Teg, 10:46 PM 11/20/2002]
Old Nov 20, 2002 | 01:49 PM
CovertFI's Avatar
Default Re: should i put a block guard? (Turbo_Teg)
if it is all stock i dont think so, but then again they are only like 100 bux.
Old Nov 20, 2002 | 06:40 PM
Turbo_Teg's Avatar
New User
need more opinions please
Old Nov 20, 2002 | 06:50 PM
B18EG6's Avatar
Ive heard overheating problems with blockgaurds...and they tend to "bend" (for lack of a better word....im up to now)
Old Nov 20, 2002 | 07:04 PM
Tofurky's Avatar
Default Re: should i put a block guard? (B18EG6)
bump. i'd like to know as well.
Old Nov 20, 2002 | 07:11 PM
Sonny's Avatar
A properly installed blockguard that is made to fit will do the trick.
There are far more horror stories about blockguards than there are success stories. People that hammer them in tend to have problems very quickly.
When you hammer in a blockguard, it distorts the sleeves. The only way you can correct for this is to bore and hone the block to get the cylinders perfectly round. People who use them with success either have one that they grind on so that it is an EXACT match to their block or they weld it in and then bore-n-hone.
They are cheap up front, but there is a lot of hidden costs in doing a blockguard properly.
Sonny
Old Nov 20, 2002 | 09:09 PM
skilzz's Avatar
Default Re: should i put a block guard? (Sonny)
Do not get a blockguard. Why? well because its a complete waste of money. It does not guard your block...it guards the outer top of your cylinders (useless) and restricts coolant flow between the cylinder head and water jackets.
Old Nov 20, 2002 | 09:27 PM
Tofurky's Avatar
Sonny
thanks man, exactly what i wanted to know
Old Nov 21, 2002 | 10:38 AM
gtcali's Avatar
I have yet to hear one from somebody first hand though. Besides cooling, and people have drilled extra holes in older blockguards and hadn't had a problem from there.
I've have heard first hand from people who use them and say they work.
Anybody had problems that has acutally used them?
I'm using one. I got it for free though. And I'm not boosted yet. Cooling is fine.
[Modified by gtcali, 7:39 PM 11/21/2002]
Old Nov 21, 2002 | 10:50 AM
TeStUdO's Avatar
Default Re: should i put a block guard? (gtcali)
mine is still sitting in my closet, maybe i should put it on ebay for like 50 bucks. i never even used the thing.
Old Nov 21, 2002 | 02:11 PM
swrdply400mrelay's Avatar
Default Re: should i put a block guard? (Ruckus138)
i have a nuformz blockguard for my turbo d16y8 and i've had it for over a year. no cooling problems caused yet. i don't know how much it helps with protecting the block, because i've only boosted to about 9psi. i got stock internals and have overboosted to 14psi a few times, but nothing's happened. didn't hammer it in either...uh not sure what else you want to know...
mike
Old Nov 21, 2002 | 03:18 PM
Heath's Avatar
Default Re: should i put a block guard? (swrdply400mrelay)
I got one and I run the dogshit out of my car! I haven't had a bit of trouble. I guess I did get the temp gauge to jump a little back in July...but it was really hot and I was holding I think 10psi at around 130mph for a little longer than I should've. I'm sure if done correctly and treated correctly it will perform correctly. Hope this helps.
Old Nov 21, 2002 | 03:54 PM
gritsak's Avatar
Default Re: should i put a block guard? (95civicturbo)
one of my buddies uses a str blockguard on his built b18c...its built for turbo but doesnt have a turbo on it yet though but anyways, he hasnt had any cooling problems, everything seems to be working great so far without boost, and hes got over 2000 miles on it.
Old Nov 21, 2002 | 04:03 PM
Turbo_Teg's Avatar
New User
Default Re: should i put a block guard? (gritsak)
what brand are you guys using?
Old Nov 21, 2002 | 05:49 PM
teger's Avatar
don't have one yet, but i'm thinking of useing an ARP block gaurd
Old Nov 21, 2002 | 06:05 PM
wanabecivicex's Avatar
Default Re: should i put a block guard? (teger)
im boosting around 9psi right now on a b18b with a built bottom end. i have had no cooling issues with it, it was hammered in and works great as far as im concerned, if you are planning on keeping the pistons and rods stock, then i wouldnt even bother, the rods will break before the cylinder walls will for sure. so if you are spending alot of money on your block, put a block guard in, really, its not going to hurt.
eg:R
Apr 19, 2014 08:56 AM
MR.johnson
Jun 2, 2008 09:33 PM
demian22
Feb 28, 2008 10:34 AM
10SecDSM
Sep 15, 2006 08:11 AM
hatchii
12
Nov 11, 2002 05:06 PM
