Should I be ok?
Old Jun 10, 2010 | 07:35 PM
Ek9 Kid's Avatar
Default Should I be ok?
So I'm gonna run 6 lbs of boost on my stock d16y5, of course ill do an obd1 conversion and do a chipped p28, but will i be fine with the stock 240cc injectors? Inputs please!
Old Jun 10, 2010 | 07:36 PM
Axix24's Avatar
Default Re: Should I be ok?
i wouldn't
Old Jun 10, 2010 | 07:37 PM
Slow_boost's Avatar
Dont chance it. Spend 50 bucks and get DSm 450s and the resistor box. It will more than enough for your current setup and give you room for more power.
Old Jun 10, 2010 | 07:59 PM
Ek9 Kid's Avatar
my buddys got a set of 300cc injectors, would i be better off with those instead of the 240cc? or are they still too small?
Old Jun 11, 2010 | 06:44 AM
EdSales's Avatar
I wouldn't boost 1 pound on 240CC Injectors. I wouldn't boost on 300CC either. That would be a really high duty cycle. What happens when you run a high duty cycle? Well, lets say the Injector for a split second can't meet the 99% demand you are asking it to do, it will cause your engine to run lean, etc, etc, then bad engine.
I had a pair for 450CC Injectors on my B16, when I found out that at 300WHP they would be 95-98% Duty Cycle, I sold them for 880CC. I will always run a larger injector that what is needed to be safe.
Old Jun 11, 2010 | 07:37 AM
AddictsRacing's Avatar
Atleast go with 440cc injectors, as stated above, you don't want to be maxxing out your injectors. To be quite honest, if I were in your position, I would up it to atleast some 550's, just so I had room to upgrade down the road.
But don't let my previous statement fool you, bigger doesn't always mean better. You don't want to over compensate on injector size because if your ECU tries to lean out a rich mixture, and in doing so selects a pulse that is shorter than the injectors minimum dynamic flow range, the injector is no longer consistant to supply the correct amount of fuel.. In which case, you'll actually be losing power / performance, rather than gaining.
Old Jun 11, 2010 | 09:48 AM
Ek9 Kid's Avatar
allright thanks, any of you have a set of 440s? i can paypal you or whatever
Old Jun 13, 2010 | 11:48 PM
dewoine's Avatar
not to thread jack but am i doing somthing wrong by not upgrading my injectors on my stock greddy kit on my d15b?..it didnt say to upgrade but then again im still on the wastegate . jst wondering
jamesfawcett
Apr 13, 2010 01:33 AM
boostcrazy1234
Apr 14, 2008 10:19 AM
TurbodTegSfaria
Nov 14, 2006 04:07 AM
JSMC
Jul 26, 2003 01:43 PM
BoostedH23a1
Nov 21, 2002 02:54 PM
