Should I keep this Wideband O2 sensor?
Old May 24, 2005 | 02:34 PM
ThePro's Avatar
Default Should I keep this Wideband O2 sensor?
I bought a brand new wideband o2 sensor because it was just too good a deal to pass up. I could sell it for a few bucks more than what I paid.
But in any case, I'm having a shop tune my car. I'm going to be using Crome.
Do I actually need the wideband for anything then?
If I keep it, what do I use it for? I have an additional o2 bung welded on to my downpipe, should I run it permanently?
Permanently monitoring my AFR will do what for me?
Old May 24, 2005 | 03:45 PM
mtber's Avatar
Default Re: Should I keep this Wideband O2 sensor? (ThePro)
If your crome tuner knows what he is doing, more then likely you shouldnt have to moniter your a/f via a wideband unit. But its always a plus to have one.
Old May 24, 2005 | 04:14 PM
93supercoupe's Avatar
Default Re: Should I keep this Wideband O2 sensor? (mtber)
Its cool to have, u can notice different A/F ratios in diff. situations.It always a good piece of mind knowing ur car is @ 12 A/F all the time
Old May 25, 2005 | 07:29 AM
ThePro's Avatar
Default Re: Should I keep this Wideband O2 sensor? (93supercoupe)
Hrm... I gotcha then.
In another situation, I could probably hook my wideband up to the Crome as well as the stock o2 sensor and have it give me more accurate closed loop feedback and tuning. Is this not true?
Old May 25, 2005 | 09:06 AM
PrecisionH23a's Avatar
I would keep it. That way if anything ever goes wrong internally (headgasekt, etc) with the motor then you'll be able to tell most of the time by the AF's changing.
Old May 25, 2005 | 10:08 AM
EJ1 wilcox's Avatar
Default Re: Should I keep this Wideband O2 sensor? (PrecisionH23a)
Keep it. What if you want to change something about your setup?
Or up the boost? You don't want to have to pay for a retune every time you change something. I say keep the wideband so you can make adjustments in the future if you need to.
Old May 25, 2005 | 12:08 PM
xenocron's Avatar
Default Re: Should I keep this Wideband O2 sensor? (EJ1 wilcox)
Personally, i'd never run a turbo car without a wideband installed. Whether it was professionally tuned or not, always good piece of mind.
phoshyzzle
Oct 18, 2009 07:52 PM
odishaw
Feb 16, 2008 08:34 AM
Simple SOHC
Oct 16, 2005 12:19 AM
mdixonjam
Jul 3, 2005 10:57 AM
ChaosUnbound
Aug 25, 2004 08:12 AM
