should I boost the tired d15?
Old Feb 22, 2004 | 07:41 PM
yusoslo's Avatar
Default should I boost the tired d15?
I have a drag kit and I am building my d16z6, and was wondering should I put the turbo on my d15 with 160k miles, burns 1 quart of oil every 3,000 miles as of now.
That way if I happen to blow it, then I have my other one ready. OR should I just wait and put in my new engine. I dont have anyone wanting to buy the old one.
Old Feb 22, 2004 | 08:06 PM
warwagon's Avatar
Default Re: should I boost the tired d15? (yusoslo)
helz yeah
Old Feb 22, 2004 | 08:20 PM
Jockobo's Avatar
Default Re: should I boost the tired d15? (warwagon)
put it in...itll be fun...1 quart per 3000 miles is pretty good in my book...
Old Feb 22, 2004 | 09:21 PM
gdrum's Avatar
Default Re: should I boost the tired d15? (Jockobo)
boost it...its only like couple hundred bux if you hit up someone on dsm trader
Old Feb 22, 2004 | 11:42 PM
Nick7's Avatar
Default Re: should I boost the tired d15? (gdrum)
Yah.. boost it. If you scew something up, it's better to blow that one up than the one you're building.
Not to mention lots of experience you'll gain by installing D15..
Old Feb 23, 2004 | 06:04 AM
yusoslo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gdrum &raquo;</TD></TR><TR><TD CLASS="quote">boost it...its only like couple hundred bux if you hit up someone on dsm trader </TD></TR></TABLE>
maybe its too early in the morning, but dsm trader? for a new engine?? I'm not sure I understand you.
Old Feb 23, 2004 | 08:13 AM
gdrum's Avatar
the turbo kit....set of 390cc/450cc injectors 30-50 bux......dsm sidemount 40 bux.......14b turbo 80-100.....1g bov....walah...
Old Feb 23, 2004 | 10:07 AM
yusoslo's Avatar
i already have a turbo kit. I was debating putting in on my d15 to see what happens before I install my d16 (which will be turbo's anyways)
Old Feb 23, 2004 | 10:10 AM
Bailhatch's Avatar
Do it for the install experience, unless you do this often. It is worth it even if the D15 shoots a rod into to trunk of guy in front of you.
Old Feb 23, 2004 | 10:43 AM
gdrum's Avatar
Default Re: should I boost the tired d15? (Bailhatch)
Yeah do it for experience....putting the kit on for the 2nd time on your brand new b18 or whatever you get, ull feel so much safer knowing what corners to take here, and what to do here..........save u lot of time and headaches..doing it once and learning from the mistakes
jdmEFmike
Jun 10, 2010 05:57 PM
streetspeed607
Oct 2, 2007 07:31 PM
rmillz23
Aug 18, 2003 09:01 AM
92-h23a1
Aug 7, 2003 08:40 AM
