Should this be connected?
Old May 6, 2006 | 08:01 PM
SpeedingHatch's Avatar
Default Should this be connected?
I originally had the whole thing mounted down lower on the firewall for a cleaner look, but when I was moving things in the engine bay I touched this and the engine immediate turned off.
Ive had idle issues with it jumping up and down, so could this be the culprit? Where would it connect to? I barely move it and the engine drops in revs. WTF
Old May 6, 2006 | 08:06 PM
Jaker's Avatar
Default Re: Should this be connected? (SpeedingHatch)
That plug if for your OEM MAP sensor. Looks like there some crappy *** wire taps there for the GM MAP sensor you're using. Probably a loose connection there with the wire taps. Solder those wires up with heat shrink tubing, and you'll be golden. If you're not planning on ever going back to the OEM MAP sensor, then you could take the unused plug right off and solder up the other connections.
XxRoCkMaNxNEOxX
Sep 15, 2013 01:43 PM
K i l l a B e e.
May 30, 2009 02:28 PM
airwalk07143
Mar 18, 2006 05:55 PM
drunknbass
May 8, 2005 12:57 AM
birz
Feb 28, 2005 11:15 AM
