Share your SOHC turbo setups.
I'm planning on joining the dark side soon. I'll be using my d16z6 for the engine. Wondering what some of you guys are running, and what kind of power you're getting. Oh and if you don't mind an estimate of what you've spent. I'm trying to reach into the 12s with my sohc.
Travis
[Modified by mantic6t9, 12:55 AM 9/13/2002]
Travis
Re: Share your SOHC turbo setups. (mantic6t9)
I am running 6psi and I just got a dyno not to long ago. The temp was 90 and humidity at like 80% and I had my 17" on and I was running rich. My best run was 149.3HP and 130.6 Torque. I just ordered an intercooler so that should help put down some more HP. I am hopping to get 180hp with FMIC 6-7psi and some timing adjustments.
Engine
D16Y7
Apex-i turbo kit
Apex-i turbo timer
Greddy blow off valve
Vortech FMU
EX D16y8 intake manifold
EX transmission
10lbs flywheel
ACT 6 pad clutch and
Xtreme Pressure Plate
Fireball border exhaust
Venom fuel rail
255lph fuel pump
B&M fuel psi gage
NOLOGY Wires
Denso iridium spark plug
[Modified by mike97hb, 6:55 AM 9/13/2002]
Engine
D16Y7
Apex-i turbo kit
Apex-i turbo timer
Vortech FMU
EX transmission
10lbs flywheel
Venom fuel rail
255lph fuel pump
B&M fuel psi gage
NOLOGY Wires
Re: Share your SOHC turbo setups. (mike97hb)
That's the kit i plan on getting. How is the fitment of the apex kit. I've heard it's suposed to be near perfect. What did you pay for just the kit?
D16Y5
T25 turbo
VX manifold
HKS BOV
Inline Fuel Pump
Cartech FMU
Starion Intercooler
Custom
Custom
Custom...
14.0@100mph non intercooled street tires/crappy clutch 9-10psi
T25 turbo
VX manifold
HKS BOV
Inline Fuel Pump
Cartech FMU
Starion Intercooler
Custom
Custom
Custom...
Re: Share your SOHC turbo setups. (bretx0r)
D16Y5
T25 turbo
VX manifold
HKS BOV
Inline Fuel Pump
Cartech FMU
Starion Intercooler
Custom
Custom
Custom...
T25 turbo
VX manifold
HKS BOV
Inline Fuel Pump
Cartech FMU
Starion Intercooler
Custom
Custom
Custom...
[Modified by mantic6t9, 1:09 AM 9/13/2002]
http://members.aol.com/Inspyral/mycar.html
8lbs daily, stock internals, stock dying clutch
new headgasket goes in this weekend
well this is my PLANNED setup... i have the parts but it's not on the car yet:
>Garrett T-3 Turbocharger (.60A/R, 60-trim comp, .48A/R turbine)
>South Florida Performance Turbo Manifold
>South Florida Performance Downpipe
>Drag Piping
>Drag Intercooler
>Greddy Type-S Blow Off Valve
>Tial 35mm .45 Bar Wastegate
Fuel System:
>DSM 450cc Injectors
>88-91 Injector Resistor Box
>255lph Walbro High Pressure Intank Fuel Pump
Electronics & Gauges:
>Apex'i V-AFC
>Greddy Turbo Timer
>Greddy 60mm Electronic EGT Gauge (Black Face)
>Autometer Sport-Comp A/F Ratio Gauge
>Autometer Sport-Comp Boost Gauge
>NGK BCPR7ES-11 Spark Plugs (0.032 gap)
Miscellaneous:
>Oil Feed Kit:
- 1ft of -4AN hose (run off the block, THEN the Tee THEN the 4ft of -4an)
- 4ft of -4AN hose
>-10AN Oil Return Line Kit
Can't wait to put it on
>Drag Piping
>Drag Intercooler
Fuel System:
>DSM 450cc Injectors
>Apex'i V-AFC
>Greddy Turbo Timer
Miscellaneous:
>Oil Feed Kit:
- 4ft of -4AN hose
Re: Share your SOHC turbo setups. (CivicRyda2k)
d16z6
rc310's
Vortech FMU w/ 8:1 disc
NOS Fuel pump
CRX HF exhaust mani
Probe GT Turbo welded onto HF Manifold
Drag II Intercooler
Custom boost piping
Best time: 13.6 /w slipping stock clutch
Right now its really fucked...turbo is almost grenaded & has a massive vacume leak... sumewhere trying to get everything back to normal...
rc310's
NOS Fuel pump
CRX HF exhaust mani
Drag II Intercooler
Custom boost piping
Re: Share your SOHC turbo setups. (N8-T)
i can only partially join this post....i got a d16z6 sol...illb e gettin my spearco intercooler, ic piping and greddy type s bov this week...im still deciding betweent eh gressy and apexi turbos tho....which do u guys think?
stock d16z6
garret t3/t04e 48ar 54 trim
big spearco intercooler
450cc DSM injectors
afc hack (-40%)
stock FPR and about 60psi fuel pressure at full boost.
12psi when its cool at nite and she pulls like crazy. Im guessing at 12psi im somewhere around 200-220hp @ the wheels.
My best time is a 13.4 @ 106mph in colorado at 5400 feet on street tires. here in san diego im sure i could do better...someday ill go and try. Im pretty sure i can do a 12 if i can get a good launch.
liam
450cc DSM injectors
afc hack (-40%)
liam
Re: Share your SOHC turbo setups. (liam821)
stock d16z6
450cc DSM injectors
afc hack (-40%)
liam
450cc DSM injectors
afc hack (-40%)
liam
I am now inspired to crank my boost...on occassion
I'm running:
Greddy Manifold
Garrett t3 .48/.42
DSM intercooler (gonna get something bigger and front mount it. it's in the fenderwell right now)
DSM 450's with custom fuel trim circuit (works well, but I'm tuned way rich for the moment)
Bosch BOV
2" charge pipes
2.5" DP with 2.25 exhaust
Boosting 7psi (upping to 10 when I get the *****)
Only info I have is that it pulls hard even though the stock clutch is slipping up top.
inspyral and liam821: I see you guys are running t3/t4's in your setup.
Say 2nd-4th @ what rpm do you start to spool and when is full boost reached?
Do you like the t3/t4 on the d16?
Reason I ask is cause I am looking to turbo my sohc also. I am either going to get a revhard kit w/ comes w/ a t3/t04b (.50trim comp w/ .63 a/r turbine).
Or getting in on this GB: https://honda-tech.com/zerothread?id=278085
Getting this turbo:
.48 A/R Turbine Housing
Stage III Turbine
.60 A/R Compressor Housing
57 Trim Compressor Wheel
Thoughts/inputs welcome...
Getting this turbo:
Stage III Turbine
i've never dynoed my car. but i once raced a 92nissan240 with 75shot of n2o and i was able to keep up with him the whole time running 8psi.
The setup consists of a stock D16Y8
greddy turbo kit 15g
greddy type 31 intercooler
type s bov
vortech fmu 12:1 disk
rc 440's
apexi safc
http://photomail.photoworks.com/shar...RVRO6gIxlnDNDG
Sorry couldn't get actual pics to show up.
[Modified by autoEXturbo, 9:18 AM 9/13/2002]
type s bov
rc 440's
apexi safc
Re: Share your SOHC turbo setups. (autoEXturbo)
Hey autoEXturbo:
How does the automatic transmission hold up to the turbo? Do you get any boost spikes? My wife wants more power for her 98 EX auto, and I was looking at the Greddy kit as well.
BTW, that FMIC looks bada$$!
Re: Share your SOHC turbo setups. (S)
Im running a Drag 3 kit on my single cam. It only the 1.5 non VTEC.(D15B7). Got it dynoed the other day. I just got a base run. No tunning performed. It was mainly done to check my fuel. It was like 90 degrees and humid, and she put 153whp and 145.4 tq. Not alot, but i only dynos at 86 to the wheels stock. Picked up 67 to the wheels. That was eight pounds. Now im gonna put about 11 on her *** and get everything dialed in and see if the old 1.5 can lay down about 200whp.
Re: Share your SOHC turbo setups. (Prelude_RCR)
thanks for the compliment. I had no boost spikes what so ever, boost gauge always read no higher than 8psi and that's what i was shooting for. The tranny did great, i was very surprised. Just make sure when you do the greddy kit that if you are seriously racing when you feel it wants to shift gears, let off the gas. I know that the automatic clutch or whatever it has can slip if abused. But at 5psi, she ran strong and pulled at 14.9@94
Re: Share your SOHC turbo setups. (DevilSolSi)
How can you buy an IC and piping and not even know what turbo/manifold etc you're going to be using?
I'd say you are going to end up buying some stuff twice.
Here's my setup that will go on a d16z6 with an auto tranny
DSM td05h-14b
STD manifold
DSM sidemount ic
DSM BOV
custom downpipe and testpipe(still need to make)
custom piping(still need to make)
-afc hack
DSM 450cc injectors
Walboro 255lph fuel pump(Still need to get)
APEXI v-afc
I'll definaltey be boostin this spring I'm still waiting on a few parts, if not maybe later this fall if I happen to get impatient
[Modified by AztecEJ, 2:55 PM 9/13/2002]
DSM td05h-14b
STD manifold
DSM sidemount ic
DSM BOV
-afc hack
DSM 450cc injectors
APEXI v-afc
Re: Share your SOHC turbo setups. (Midwestrider)
Re: Share your SOHC turbo setups. (inspyral)
D16Y8 w/ 110k miles
GReddy TD04H-15G kit w/ FMIC
RC 440cc injectors
Walbro 255lph intank pump
Hondata 2B
custom 2.5" DP
custom 3" catback
217.7whp @ 10psi
183wtq @ 10psi
180whp @ 6.5psi
Best 1/4 mile (pre-Hondata)
On 12psi- 14.1 @ 100.7 with a 2.4 60' time on stock Firestone P185's
Highest trap @ 12psi- 102mph
Only took it once since the Hondata on a set of Nitto's which sucked, pulled a 2.3 60' time but only got a 14.3 on 10psi. Haven't taken it since the new tires..
[Modified by VTC_slow_CiViC, 10:40 AM 9/13/2002]
RC 440cc injectors
Hondata 2B
custom 2.5" DP
custom 3" catback
217.7whp @ 10psi
183wtq @ 10psi
180whp @ 6.5psi
Re: Share your SOHC turbo setups. (VTC_slow_CiViC)
I'm planning on getting the Apex turbo kit. Will this turbo support my 12sec goal? The other kit was the rev hard 2c kit. I'm leaning toward the apex kit for the ball bearing turbo. I can get both for right around the same price.
Travis
Travis
mike....
How did the D16Y8 manifold fit in the hatch?? Did it just bolt right up, or did you have to make any mods to it?
Sweet looking ride!
Sweet looking ride!
Re: Share your SOHC turbo setups. (Marauder)
MY Setup
Zc sohc (low kms) IHI VF8 turbo off a 2l subara legacy RS, Custom manifold equal length runners HPC coated , 2.5 in dump pipe to flexi joint, 2.5 in mandrel bent, 1 resonator, No cat, 2.5 in stainless muffler,Intercooler from starion polished, 2in mandrel intercooler piping HPC coated , racepro blowoff valve, 4 in air intake off turbo big simota filter, 3 extra injectors, Hi flow fuel pump, Tuning turbo LINK piggy back chip. Daily:8psi170whp Track10psi196whp
http://homepages.ihug.co.nz/~edastill/honda.htm
Spent about $5500 NZ dollars so half it for US, any of you guys thinking about running more then 7psi get on a dyno and tune it properly or you will be sorry.
