Setup is almost done, what else do I need??
Old Aug 10, 2003 | 05:16 AM
TTWS6.
Guest
Posts: n/a
Default Setup is almost done, what else do I need??
Car-- 94 EX coupe
Motor- b16a2 with Odb1 harness ( Je pistons,eagle rods, blockguard)
drag 3 kit with everything except FMU which I sold. I ordered new 780cc injectors from KSmotosports which are on the way, and the only things I have planned left to get are:
12.5# flywheel
AEM ems
255lph fuel pump
for now 350ish hp will do. so is this everything I need, or am I forgetting something?
btw I have 310cc's for sale PM if interested.
Old Aug 10, 2003 | 06:32 AM
TTWS6.
Guest
Posts: n/a
ttt
Old Aug 10, 2003 | 07:15 AM
metal-x's Avatar
Default Re: (TTWS6.)
off hand you need resistor pack, injector clips, boost controller,GM 3 bar map sensor, AEM boost celenoid and definately a better clutch
Old Aug 10, 2003 | 07:22 AM
bo0sted's Avatar
Default Re: (metal-x)
Turbo Timer?
Old Aug 10, 2003 | 07:36 AM
u2civic1's Avatar
better WG
Old Aug 10, 2003 | 07:43 AM
94TurboGSR's Avatar
Default Re: Setup is almost done, what else do I need?? (TTWS6.)
Some extra gauges wouldn't hurt: EGT, Oil Pressure, etc.
Old Aug 10, 2003 | 07:51 AM
TTWS6.
Guest
Posts: n/a
Default Re: Setup is almost done, what else do I need?? (TealTurbo)
I have a 3 puck clutch, and do I really need a boost controller WG and resistors with AEM EMS? I thought the solenoid replaced the wastegate?
Old Aug 10, 2003 | 08:19 AM
TurboJesse
Guest
Posts: n/a
your gonna need resistors if you injectors are peak and hold.
Old Aug 10, 2003 | 10:44 AM
MotorMatrix.com's Avatar
I am a bad person
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TTWS6. &raquo;</TD></TR><TR><TD CLASS="quote">I have a 3 puck clutch, and do I really need a boost controller WG and resistors with AEM EMS? I thought the solenoid replaced the wastegate?</TD></TR></TABLE>
youll need the resisitor box and a wastegate for sure. what do you think will regulate boost at the manifold?? besides having a hole in your manifold.
Old Aug 10, 2003 | 11:13 AM
TTWS6.
Guest
Posts: n/a
Default Re: Setup is almost done, what else do I need?? (MotorMatrix.com)
I dont know much about the GM solenoid, my fault for assuming it replaced the WG, so what exactly does it do?
Old Aug 10, 2003 | 02:54 PM
TTWS6.
Guest
Posts: n/a
ttt
Old Aug 10, 2003 | 04:58 PM
TTWS6.
Guest
Posts: n/a
Mike?
Old Aug 10, 2003 | 05:38 PM
spoolinlude's Avatar
I live under a rock
The GM map makes it possible to boost past roughly 1 bar....... without it you won't read positive boost past around 1 bar....the wastegate regulates boost, the map sensor just reads manifold air pressure and regulates... basically your ecu will freak out on you........ and a bunch of other stuff happens........ not really sure thou........ never found out what happens with that much boost on a non-stand-alone car....but u have AEM so ......... ure good
Old Aug 10, 2003 | 05:57 PM
TTWS6.
Guest
Posts: n/a
Default Re: Setup is almost done, what else do I need?? (spoolinlude)
what aqbout the solenoid?
Old Aug 10, 2003 | 07:57 PM
TTWS6.
Guest
Posts: n/a
up
Mr. Lucky
Honda S2000
35
May 11, 2006 12:17 PM
11psiTurboSI
Apr 15, 2004 09:53 PM
integra95
Sep 21, 2003 01:41 PM
C-Murdock
Nov 7, 2002 08:11 PM
integra-modder
Sep 21, 2002 04:55 PM
