What else needed in turbo GSR w/ AEM EMS?
Im going to be running the AEM EMS. I also have a walbro 255lph fuel pump. Probably going to get the RC 550 CC injectors. What else do you guys suggest I get?
Re: What else needed in turbo GSR w/ AEM EMS? (Inlinefour)
3 bar map sensor.
Typhoon boost control solenoid.
A good tuner.
A good tuner.
yes, I already have a resistor box from an older CRX.
Re: What else needed in turbo GSR w/ AEM EMS? (integra-modder)
what are those needed for?
To use the boost control function that the EMS has built in.
these should be it:
gm boost solenoid # 1997152 ($8.84)
gm 3 bar map sensor # 16040749 ($49.08)
handling/freight charges are like $18 but it's well worth it, check out your gm parts dealer prices.
Re: What else needed in turbo GSR w/ AEM EMS? (Arturbo)
Does anyone have the GM part # for the 3 bar map sensor harness?
art
art
maybe this one Art:
12085502 MAP (Wire Pigtail)
someone clarify/verify this though.
correction to part number above.
[Modified by justagsr, 9:11 AM 9/5/2002]
Re: What else needed in turbo GSR w/ AEM EMS? (justagsr)
maybe this one Art:
12085502 (Wire Pigtail)
Thanks guys, for the record the part# is #12102747 ..
art
art
MAP sensor pigtail is #12085502 and has to be modded to fit.
art
I just read the link I posted thoroughly, the pigtail for the boost control solenoid is #12102747.
art
Re: What else needed in turbo GSR w/ AEM EMS? (downpipe)
16040749
Computer Control Sensors
SENSOR AS
$49.08
$49.08
$49.07
$0.00
$9.82
$58.90
12085502
CONNECTOR
$14.38
$14.38
$14.38
$0.00
$7.95
$22.33
1997152
All
SOLENOID
$8.84
$8.84
$8.84
$0.00
$5.25
$14.09
so are those the three things i need?
1997152, 16040749, 12085502 ?
its 95 bucks
SENSOR AS
$49.08
$49.08
$49.07
$0.00
$9.82
$58.90
12085502
CONNECTOR
$14.38
$14.38
$14.38
$0.00
$7.95
$22.33
1997152
All
SOLENOID
$8.84
$8.84
$8.84
$0.00
$5.25
$14.09
its 95 bucks
"Resistor box"
what is this?
also why does he need GM parts?
[Modified by 95GS-R, 3:30 PM 9/5/2002]
what is this?
New User
Re: What else needed in turbo GSR w/ AEM EMS? (DamonBoost)
Here's Hondata's page on the 3 bar and pigtail modification. That's what I used for my install. Also they stated Pep Boys carries it, but they don't it's been discontinued. I ordered mine locally from AC Delco warehouse. Hope this helps. Later Allen
