setting up the AVC-R
Old Apr 17, 2002 | 06:50 PM
Aeka GSR's Avatar
New User
Default setting up the AVC-R
to make sure I wouldn't overboost i set the boost to .2 bar and set the duty to 20% but when I make a run I boost over 7psi. Isn't .2 bar supposed to be like 4 lbs? Whats going on?
Also whats the gear settings for the GSR?
edit: oh also where should i splice the little paper filter?
[Modified by Aeka GSR, 7:52 PM 4/17/2002]
Old Apr 17, 2002 | 07:02 PM
Pritos's Avatar
New User
Default Re: setting up the AVC-R (Aeka GSR)
The lowest boost you'll hit is whatever your WG spring is rated at. If you have a 7psi spring then you can't go any lower... just higher.
I bought my AVC-R used and it didn't come with that filter. When I installed a Profec-B on a friends car, it went between the boost source line and the pressure sensor on the Profec unit. For the AVC-R, I have 2 guesses, between the boost source line and the solenoid, or the boost source line and the pressure sensor.
Old Apr 17, 2002 | 07:05 PM
Aeka GSR's Avatar
New User
Default Re: setting up the AVC-R (Pritos)
aww man, i thought id be able to go lower with an internal wastegate. oh well. Thanks for the info.
Anyone know what the gear settings are?
Old Apr 17, 2002 | 07:16 PM
Pritos's Avatar
New User
yipes, forgot aobut the gear judge..
You have to drive to determine those settings. If I remember right, if you are going to set the gear judge in first drive in first gear and look at the N/S data on the right side... then set the 1st gear to that number... same with 2-5.
piece of cake
Old Apr 17, 2002 | 07:29 PM
Quaalude's Avatar
with my avcr, i was able to set boost to 8 psi with a 0.65 bar spring in the WG....try setting the duty cycle higher...also the gear judge has a self learning mode where u drive around and are able to set it, look in the manual
Old Apr 17, 2002 | 08:24 PM
Aeka GSR's Avatar
New User
Default Re: setting up the AVC-R (Quaalude)
ah so thats what the gear learning is fo. I'll also check out the duty cycle in the morning.
Old Apr 17, 2002 | 08:56 PM
98civicEX's Avatar
no, gear learning is just the O O O O O, gear judge is the actual # you put in for each gear....just bring someone w/ you, haul *** down the road, and remember the # right before you shift into the next gear...and repeat steps...have fun the AVCR rocks
prahaian
Jan 8, 2014 11:46 AM
eg:R
Engine Management and Tuning
Feb 10, 2012 11:09 AM
90Rexx
Aug 11, 2010 05:05 AM
aleks77
Nov 24, 2008 04:57 AM
