Seperate vacuum source for Boost gauge and BOV?
Subscribe
Jan 31, 2003 | 05:18 PM
I'm a little confused as to how I should be hooking this up. Currently, I have the BOV t-'ed off of a vacuum source at the end of the fuel rail (I think it's the top of the FPR).. now, to add a boost gauge, should I just put a 4-way fitting here and run both the BOV and the boost gauge as well as the FPR off of this one vacuum source, or is that asking for trouble?
If I should run seperate vacuum sources, can anyone tell me where another vacuum source on the D16Z6 motor? Is there another one on the intake manifold somewhere or what?
Reply 0
Jan 31, 2003 | 05:46 PM
Re: Seperate vacuum source for Boost gauge and BOV? (M-EJ1)
My BOV and Boost controller are both off the FPR right now. My boost gauge it directly off the cruise control vac source since I don't have cruise control
Reply 0
Jan 31, 2003 | 06:39 PM
Re: Seperate vacuum source for Boost gauge and BOV? (CzanSOHC)
hey man can you get mea pic of where u teed the bov and boost controller off??? i was thinking of putting my boost controller on the turbine though..would teeing off the bov and boost gauge from the same source, be good or bad?
Reply 0
Jul 12, 2005 | 03:31 PM
Re: Seperate vacuum source for Boost gauge and BOV? (GOLDBERG)
i woild like to know as well if you can hok up a boost gauge from the compressor nipple because i have two. would this also give you a vacuum reading or just boost?
Reply 0
Jul 12, 2005 | 03:37 PM
Re: Seperate vacuum source for Boost gauge and BOV? (hamburgler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hamburgler &raquo;</TD></TR><TR><TD CLASS="quote"> i woild like to know as well if you can hok up a boost gauge from the compressor nipple because i have two. would this also give you a vacuum reading or just boost?</TD></TR></TABLE>
That location would only provide a boost signal. You need to tap something on the manifold, after the throttle body for a vac reading.
Reply 0
Jul 12, 2005 | 03:53 PM
I just drilled a hole in the bottom of the manifold and made a source for my vacuum distribution block, this gives a cleaner look.
Reply 0
Jul 12, 2005 | 08:02 PM
Re: (slomofo)
has anyone else ever actually drilled a hole in the back of the IM? this sounds a little sketchy
Reply 0
Subscribe
